I am unsure about the battery doorbell.
I had the same issue, I had to use the primary account, because the secondary account cannot see my devices
… And you did log out of the second account after you accepted the invitation? Otherwise you would block the account again. Just asking…
Did you check it had installed the files to …/custom_components/eufy_security/ ? Did you restart home assistant?
I had an automation set to turn on the camera service every 3 minutes so the feed would always show up on my HA screen - but I’ve discovered that for some reason this seems to bork the motion detection on the eufy app, I’ve been getting barely any motion detection on the doorbell even with the settings set to maximum.
Tonight I turned off my automation and sure enough, motion detection is working great now!
Just a heads up!
After update my home assistant, eufy integration not working anymore, I tried to delete the integration and add it again the entity disappeared.
Is there anyone know how to solve this issue ?
I too …
The integration don’t import anything, after update Home Assistant 2020.12.0
Snifff…
Here the same story after the update of HA and the HA-OS
Hope there is a quick fix
Hello, does this works for eufy 1080p indoor pan and tilt indoor camera?
Hi guys, I had this integration working to some extent in Hass.io but the I changed course and went containers. I am getting this error in my logs after adding the integration and restarting:
2020-12-15 10:52:24 ERROR (MainThread) [homeassistant.components.camera] Error while setting up eufy_security platform for camera
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 199, in _async_setup_platform
await asyncio.shield(task)
File “/config/custom_components/eufy_security/camera.py”, line 31, in async_setup_entry
[EufySecurityCam(hass, camera) for camera in api.cameras.values()], True
File “/config/custom_components/eufy_security/camera.py”, line 46, in init
self._ffmpeg_image_frame = ImageFrame(self._ffmpeg.binary, loop=hass.loop)
TypeError: init() got an unexpected keyword argument ‘loop’
Not sure what to make of this…
TIA!!
The integration is currently broken on version 2020.12 of HASS. No eta on fix.
No, it works on all versions of HomeAssistant (usually) as it’s a custom component. However, something changed with the latest release and there’s no fix.
ok so I’d have to downgrade home assistant? can that be done? if so what build?
Put in a PR for a fix that appeared to work for me.
I had the same problem but I found fast solution.
Please remove from camery.py parameter loop=hass.loop in line 46 and 47
Agreed. The fix is to edit config/custom_components/eufy_security/camera.py
, replacing lines 46 & 47 with
self._ffmpeg_image_frame = ImageFrame(self._ffmpeg.binary)
self._ffmpeg_stream = CameraMjpeg(self._ffmpeg.binary)
The loop
argument that throws the error was removed in this commit https://github.com/home-assistant/core/commit/0cf3736162ac8aa5cf52fe2d6b18499875fc0ed9
I noted today that iobroker seems to have support for many of the parameters and features we have all been asking for (Motion detected, Person detected, Change guard mode, Ringing Doorbell). I also understand that iobroker can connect to home assistant (ioBroker.hass). As I am relatively new to coding however I am wondering how easy it would be to port to code to home assistant rather than bridging Home Assistant to Eufy via iobroker.
The ioBroker project I am referring to is here…
I have no programming knowledge but would love to test this if someone needs a beta tester
+1 I can help with testing
