Eufy Doorbell Ringing Automation
I recently bought a Eufy Doorbell (T8210) with Homebase 2, additionaly I installed the Eufy Security integration where I can find some additonal Sensors like for example the Doorbell Ringing Sensor.
Since a couple of days I’m experimenting to let my Lamps Flash in the Livingroom and let my Google say something if someone is pressing the doorbell.
The thing is if I run the automation manually everything works but as soon as I press the Doorbell nothing happens!?
I use within my automation that if the state is changing to “true” the automation should run, Within the Eufy Security integration I see the state changing from “false” to “true” if I press the doorbell.
What is going wrong or what am I doing wrong :-), hopefully someone can point me into the right direction.
Thanks in advance.
alias: Deurbel Eufy Test 2
description: ""
  - platform: state
    entity_id:
      - binary_sensor.doorbell_ringing_sensor
    to: "true"
condition: []
  - service: switch.turn_on
    data: {}
      entity_id: switch.deurbel
    enabled: true
  - repeat:
      count: "5"
      sequence:
        - service: light.turn_on
            rgb_color:
              - 235
              - 15
              - 15
            brightness_pct: 100
            flash: short
            area_id: huiskamer
      brightness_pct: 100
      rgb_color:
        - 246
        - 9
        - 9
      flash: short
      area_id: huiskamer
    enabled: false
  - service: tts.google_say
      entity_id: media_player.nesthub07fb
      message: Er staat iemand aan de deur
mode: single
Please try changing “true” to “True”, capital T instead of small t.
  - entity_id:
      - binary_sensor.front_doorbell_ringing
    platform: state
    to: "True"
The above clip is from my automation and I found that unless I used True (with T capital), the automation would not work,
Yes… Changing small t into Capital T solved my Issue, many thanks for helping!
both of you, please move into latest version, it should be on / off rather than True/False and it is fixed now
Hi fuatakgun,
Thanks for your additional information, I installed the latest version (V6.20) after installation I noticed a lot of features were added, but also a lot of features have the state “unavailable” or mentioning that the entity is no longer being provided! by the Security Integration…
I’m using Eufy Security Add-on version 1.3.0
After Restarting the Security Add-on every option in the Eufy Integration became unavailable!?
I updated my HA to the latest release (just in case) and after restart I deleted all the “old” Entities apparently new Entities were created after installing the latest version of Eufy.
Ringing Sensor became Ringing etc. modiefied my Automation and it works now.
