Eufy e30 Smart Lock with Matter
I recently purchased the Matter enabled lock from Eufy. I have 2 of their other locks working fine with home assistant (c220 and a retrofit model). The original 2 locks us the Eufy security add-on no problem.
My issue is the new matter enable lock does not work through the Eufy security add-on (no controls or anything enabled). So I attempted to add the lock through matter to home assistant. Once I did that the lock worked and functions properly. However as soon as I leave my house I can no longer control the lock, and it shows up as “unavailable” and will not work again until I remove the device and readd it. then the cycle repeats.
Any thoughts or help appricated
Did you figure it out? I was looking into purchasing this lock, but will stay away if it doesn’t have good support for Home Assistant.
Hey yes I did. I reached out to them and they issued a firmware update and since then I’ve had no more problems.
leitenky
I did:
  • setup lock in eufy app - all works great
  • updated lock to latest firmware v1.0.9.0
I am trying to add it to HA - eufy app does not provide setup code.
If I try to setup as new device - it will require removing from eufy app I believe.
Not sure what would be good way to do that. Really appreciate suggestions.
Can you provide more details on how to add it to Home Assistant?
hey there. can you please walk me through the steps on how to get the locks to show up in HA? I dont see EUfy Security in add ons or in integrations
Good evening. I am new to this and I saw that you were able to get your Dufy C220 locks to work with home assistant. I have been trying for two weeks with no luck. Do you have any suggestions that I can use to link them up?
I also have the E30 lock with Matter Support.
Added Eufy addon and it recognises the lock, but only shows:
Sensors
Debug (device)
On
Debug (station)
On
