Eufy Motion Sensor from Cam 2c Pro in Automation
Hi all,
I have installed in the eufy_security integration and it works so far. I can see the motion state change from false to true when motion is detected in the integration (Also in the security app I see the motion event).
But when I try to create an automation (when motion sensor detect a motion then switch on a light) it dosn’t work. The automation are not running. I tried with device and with state. I have some similar automations with other devices and no problem with these.
It must be a problem with eufy but the strange thing is I can ss chnage from false to true in the integration and I have no error messages in the logs, so in my understanding it should work… but it do not :frowning:
Have someone similar expierence or a advice what can I do? Thanks in advance.
That is a legacy issue coming from integration (yes, my bad :slight_smile: ) binary sensors normally supposed to be on/off but i set eufy_security as True/False by default, unintentionally. Anyway, if you enable the option in integration configuration panel to fix this, all automations would work as you expect to have.
oh man, I have seen but thought nothing of it :wink:
Works great now, thanks for the hint and… good job :slight_smile:
I don’t see option please upload image thanks
