Hi All,
I recently got a RoboVac 30C. Hoping you may be able to steer me in the right direction here. I feel like I’ve tried everything in this thread, but still am unable to get the device Controls to work in Home Assistant.
I am able to see the entity, can track that it is “on” or “cleaning” and even track the battery % as it goes down or it charges. However, none of the controls or actions work.
I’ve been successful getting the device ID and the token using bluestacks and ADB. I added the repository, and I tried changing the line in the tuya file from (3,3) to (3,1). When I have it at (3,1), the entity never really loads correctly. When using (3,1) I see status “error” and the battery is just a question mark.
When I put it at (3,3) the entity loads, and tracks the battery, etc, but the controls do not work.
I’ve completely removed the repos and then readded, regrabbed the IDs (they hadn’t changed), readded the config details. Any other ideas?
Here are some of the log errors that popup.
#1
Logger: custom_components.eufy_vacuum.tuya
Source: custom_components/eufy_vacuum/tuya.py:562
Integration: eufy_vacuum
First occurred: 2:20:36 PM (5 occurrences)
Last logged: 2:21:36 PM
Failed to decrypt message from 51038008caaxxxxxxxx (192.168.xx.xx:6668)
#2
Source: custom_components/eufy_vacuum/tuya.py:410
Expecting value: line 1 column 1 (char 0)
