Eufy Security Integration
Hello after successfully setting everything up I can now see my Eufy Doorbell Cam in home assistant. I am having al little bit of trouble getting it set up in frigate. What should the RTSP address of the doorbell cam be? I am trying ‘rtsp://localhost:8554/mystream’ but that isn’t working.
if your system is running well, refrain restarting your add-on otherwise you might face the same issue. Until it is resolved, please keep them running
There is a sensor for each camera for this purpose, please check it
Please check here for latest issue impacting login flow: Cannot read properties of undefined reading user_id · Issue #511 · fuatakgun/eufy_security · GitHub
@anon63427907 Recently my eufy door lock stopped working, It works in the eufy app but not through home assistant. When I push unlock or lock in home assistant, nothing happens.
This solved the problem for me:
  • Click Settings -
  • Click Addons
  • Click Eufy Security Add- on
  • Click Configuration
  • Click on the three dots right corner
  • Edit in YAML
  • Paste Copy this below : TRUSTED_DEVICE_NAME: DEVICENAME
  • Save and restart Eufy Security Add-on
My code:
USERNAME: [email protected]
PASSWORD: "You Password"
COUNTRY: LU
EVENT_DURATION_SECONDS: 10
You are my hero!
Not me :slight_smile: fuatakgun
For “TRUSTED_DEVICE_NAME: DEVICENAME”. Fixed my issue that was making me crazy trying to figure out why stopped working,
For those using the docker setup:
image: bropat/eufy-security-ws:0.9.4
Add the above fix as an env in your docker-compose file or docker run command:
    environment:
      - [email protected]
      - PASSWORD=PASSWORD
      - COUNTRY=GB
      - TRUSTED_DEVICE_NAME=DEVICENAME
hi did you solve this issue? i have the same problem
are there any users out there, receiving captcha requests recently? I am trying to find a way out to replicate captcha request with my accounts but failing to do so. Please like this post if you are receiving captcha requests recently, I will contact with you.
With apologies for being a pest, will you be addressing issues at any point? My instance of your addon/integration hasn’t worked in over a month now, except for allowing me to lock and unlock my door. None of the camera feeds show.
No need to apologize but streaming specific issues are very scattered, i am not even sure where to start. But before focusing on anything specific, i need to update the add-on and integration. It is probable that some of these issues might be resolved after the updates.
I have updated the add-on with latest version from bropat@, it is 1.1.0 version, please update it and reload the integration after it has started correctly.
I have not updated the integration yet, still working on this but without bumping schema version, it is backwards compatible. big shout out to @bropat again :clap: :clap: :clap: :clap:
I’ve updated the add-on, but now the integration is not working anymore.
Tried to restore version 0.9.4. of the add-on, but even with the old add-on running, the integration is not working anymore. :frowning:
The integration says: Retrying setup: Start Listening was not completed in timely manner
In the core log:
This error originated from a custom integration.
Logger: custom_components.eufy_security
Source: custom_components/eufy_security/coordinator.py:90
Integration: Eufy Security (documentation, issues)
First occurred: 16:15:42 (14 occurrences)
Last logged: 16:34:09
eufy_security - no devices available yet
@TexTown. Exactly the same issue here.
Have you tried this solution @breakthestatic @orangelizard? Seems to have worked for me.
Excellent, that worked!
I just added 1 line to the YAML config of the Add-on:
Still on 0.9.4. now, but retrying the update again soon.
Update: still working after the update.
Yup, this works
