I have also the same problem.
When u start the stream most of the time you get the message error.
But the stream will most of time load after 5 a 10 seconds
Surprisingly after upgrading Hass os to 7.2 (and host reboot) the errors are gone for 4 hours already. Not sure if related (either reboot or upgrade) but will keep an eye out
for always-on (mains/usb powered) rtsp supported devices, RTSP is always being streamed by device, so it will be almost instant to start live stream inside home assistant.
for battery powered rtsp supported devices, RTSP stream is started on demand, so it takes time on device to start the stream, nothing we can do.
for always-on (mains/usb powered) p2p supported devices, it will take at 1-2 seconds to start streaming inside HA, as we are generating the video stream while using incoming video bytes. (it came from 15 seconds down to here:) )
for battery powered p2p supported devices, it will take 3-4 seconds to start streaming inside HA, for the same reason one point above and waking up the device.
Thank u for your answer.
I am pretty new to home assistant so iām learning it.
I have it worked but with the error message sometimes that it cant find the url and after a second or 5 a 7 it plays the stream.
I put 2 screenshots here of my two conditional cards. Is this right or maybe i do something wrong?
I also want to thank u for all this hard work for this plugin.
Eufy announced a new app version today/yesterday. Initial response in the forum are not positive, EG. Missing notifications. Donāt know if related but perhaps Eufy changed its settings server side and are slowly migrating users ?
I am on the beta and this integration works with it without issues. I did have to reset my notification settings in the app to get it to work in the Eufy Security integration.
I donāt think the new app version has anything to do with problems some are having here.
Iāve got this new app at least a week before Eufy announced it. it works the same as beforeā¦ except new interface. Notifications for me are still coming in like usual. And integration is working the same way as before.
+1 ā¦Iām having the same problem. Worked fine for months, but after the iOS app updated (and the method for sharing the devices to a second account it seems), I simply cannot get a successful connection.
Iāve deleted, reinstalled, created a new Eufy account etc. and still the issue persists.
Same errors as reported by @skank, so something odd going on.
I have a question about the alarm_control_ panel status: from HA I can see and change it to armed home, armed away and disarm, but also to the custom status in the developer tools. When I see the same entity in HA Overview and in HomeKit through the HASS Bridge, I can only command the main three status and not the custom ones. How can I solve this?
As you rightly point out, Eufy has implemented some new features with version 4 of the app, including the creation of custom āhousesā for sharing devices.
Those who already use version 4 of the app and share the devices with it will not see them at the moment via the eufy-security-client integrations.
I have already had a quick look at the code and can tell you that it will not be a problem to support this.
I just donāt have much time for hobbies lately, so please be patient.
In the meantime, use a version < 4 of the app (IOS and Android) with eufy-security-client integrations for sharing devices.
