what kind of cameras? i have the 2K Video Doorbell and a Solocam E20. On the doorbell person detection does work but video doesnt work at all and i don’t see how to access the snapshots. so not really much use.
Pretty much the same situation with the Solocam except that its in a permenantly unknown state in HA and can’t be set to Home/Away.
options seem to be:
Remove Eufy integration from HA and just use the Eufy app seperate from HA
Give up on Eufy as a bad job and look to find other equipment that works with HA. I’m thinking of replacing both cameras with any other battery powered camera, the doorbell with any battery powered switch and using Frigate for person detection, which already works very well with my wired cameras.
i’m not someone that expects HA to run without issue, i don’t mind a regular tinker. but i’d say its now been 6 months of not working and no indication that will change
Hi, just start using this integration. Works well.
I don’t get the person_name attributes being populated though even though I can see in the Eufy Doorbell app that a person was detected and recognized. Anyone had success getting this in HA?
Hi - is there a way to arm into schedule mode on Eufy if we have a keypad? Eg. I have CUS on the keypad set to schedule. Not hurrying to rebuild the schedule as it is finicky and I usually end up setting things wrong. Can I use that button maybe somehow to arm in schedule mode?
If I press start stream on the device itself it will change the logbook to show the queue size but when I view the camera its still slowing cannot find URL.
I’ve installed the addon now twice following all steps. It looks like it is working but I have a strange problem with all of my entry sensors. It seems they are not updating when a door is opened or closed.
I figured that the open/close event is to short before a new “fetch” but also when I open a door for longer then, let’s say, 30 minutes it’s not updating. I looked in the logs and found it full of errors. Any suggestion on what to do?
at P2PClientProtocol.handleDataControl (/usr/src/app/node_modules/eufy-security-client/build/p2p/session.js:1450:43)
at P2PClientProtocol.handleData (/usr/src/app/node_modules/eufy-security-client/build/p2p/session.js:1043:18)
at P2PClientProtocol.parseDataMessage (/usr/src/app/node_modules/eufy-security-client/build/p2p/session.js:1031:26)
at P2PClientProtocol.handleMsg (/usr/src/app/node_modules/eufy-security-client/build/p2p/session.js:868:26)
at Socket.<anonymous> (/usr/src/app/node_modules/eufy-security-client/build/p2p/session.js:1732:56)
at Socket.emit (node:events:513:28)
at UDP.onMessage [as onmessage] (node:dgram:930:8),
payload: '{"cmd":1550,"payload":{"status":0}}\x00'
2023-05-17 17:14:44.887 ERROR Station T8010P2322381E5F - CMD_NOTIFY_PAYLOAD Error:
error: SyntaxError: Unexpected token in JSON at position 35
at JSON.parse (<anonymous>)
payload: '{"cmd":1550,"payload":{"status":1}}\x00'
2023-05-17 17:15:04.631 ERROR Station T8010P2322381E5F - CMD_NOTIFY_PAYLOAD Error:
2023-05-17 17:16:21.928 ERROR Station T8010P2322381E5F - CMD_NOTIFY_PAYLOAD Error:
2023-05-17 17:16:25.998 ERROR Station T8010P2322381E5F - CMD_NOTIFY_PAYLOAD Error:
2023-05-17 17:21:29.544 ERROR Station T8010P2322381E5F - CMD_NOTIFY_PAYLOAD Error:
2023-05-17 17:21:35.362 ERROR Station T8010P2322381E5F - CMD_NOTIFY_PAYLOAD Error:
2023-05-17 17:32:07.292 ERROR Station T8010P2322381E5F - CMD_NOTIFY_PAYLOAD Error:
Once I reboot the addon and reboot home assistant everything seems to work fine. The log shows me the following but after a while it goes back to what happened above…
2023-05-17 18:05:59.105 INFO Eufy Security server listening on host 0.0.0.0, port 3000
2023-05-17 18:06:09.324 INFO Connected to station T8010P2322381E5F on host 192.168.1.180 and port 25192
2023-05-17 18:06:12.764 INFO Push notification connection successfully established
2023-05-17 18:07:13.363 INFO Disconnected from station T8010P2322381E5F
2023-05-17 18:07:18.444 INFO Connected to station T8010P2322381E5F on host 192.168.1.180 and port 26767
2023-05-17 18:08:22.297 INFO Disconnected from station T8010P2322381E5F
2023-05-17 18:08:27.358 INFO Connected to station T8010P2322381E5F on host 192.168.1.180 and port 18258
2023-05-17 18:09:31.248 INFO Disconnected from station T8010P2322381E5F
2023-05-17 18:09:36.310 INFO Connected to station T8010P2322381E5F on host 192.168.1.180 and port 28795
2023-05-17 18:10:40.205 INFO Disconnected from station T8010P2322381E5F
2023-05-17 18:10:45.282 INFO Connected to station T8010P2322381E5F on host 192.168.1.180 and port 17378
2023-05-17 18:11:49.131 INFO Disconnected from station T8010P2322381E5F
2023-05-17 18:11:54.189 INFO Connected to station T8010P2322381E5F on host 192.168.1.180 and port 16541
2023-05-17 18:12:49.943 INFO Alarm mode for station T8010P2322381E5F changed to: DISARMED
2023-05-17 18:12:50.504 INFO Received push notification for changing guard mode
guard_mode: 63,
current_mode: 63,
stationSN: 'T8010P2322381E5F'
2023-05-17 18:12:56.293 INFO Alarm mode for station T8010P2322381E5F changed to: HOME
2023-05-17 18:12:56.654 INFO Received push notification for changing guard mode
guard_mode: 1,
current_mode: 1,
I have a question. After a few days of trail and error I managed to get the entry sensors working in HA. For some reason the open/close state was not updating in the app while I was able to change the alarm state for homebase to away or home etc…
It turned out that the entry sensors (open / close state) only update if you allow push-notifications in the Eufy Security app. Else Eufy won’t send out the change of state.
Now its quite annoying to get notifications on my mobile all of the time when someone opens or closes a door or window so my question is, is it possible to have the open/close state in HA updated WITHOUT having 9000 push notifications on my phone. I thought about blocking the notifications on my phone from the app but that way I don’t get a notification when the alarm is triggered and that’s nor really helpful…
I have set up the rtsp camera (2C Pro) in a dashboard card the same as another one that is showing correctly but the 2C Pro is returning the above error.
EDITED: just to say, the stream does show for a few seconds after creating the card but then disappears with the error.
Yes, that’s possible. Provided you are on a relatively new Android version. If you long press the notification in android you will end up in a menu allowing you to switch off or silence notifications. It should even allow you to keep some on (eg. Doorbell press) and others off.
My apologies, i am pretty new to this. I have the add on/integration working and can see my 2 cameras and doorbell entities. But I cannot see the video either as a snapshot or live
What is the difference between the two add-ons available that enable this integration?
The first was in the original documentation when I set up, the second is in the current documentation.
I migrated to the newer and higher version add-on but my door lock can not be locked or unlocked - although the state is updated if I lock it the old fashioned way. Moving back to the older add-on and all is working as intended again.
