Question I finally got the eufy doorbell to appear. on the rtspoweb what do I put for stream url or where do I find it? I have the eufy dual doorbell camera
Why do you need rtsp to web configuration, it should work out of the box without any config, moreover i prefer web to rtc and I don’t use rtsp to web.
I wanted my live camera feed on home assistant to be accurate. Right now it just says Idle?
And you want me to understand all your setup magically? So, you followed readme, executed correct service calls etc and faced some issues and you ask help about rtsp to web?
My apologies, yes I have followed all the instructions and read me. I read this here and I looked up rstpweb. that’s why i was asking?
It says webrtc though
Try changing the url:
line to (IIRC) entity: camera.doorbell
or whatever your camera entity ID is.
Also if you haven’t already you may need to change your Doorbell entity’s Video Streaming Quality setting to “Low / Low Encoding.”
Re: The JSON parse error, there’s an open issue in the eufy-security-client repo here: [Bug]: JSON parse error · Issue #344 · bropat/eufy-security-client · GitHub
Did i do something wrong?
square: false
columns: 1
type: grid
cards:
- type: conditional
conditions:
- entity: camera.doorbell
state: idle
card:
show_state: true
show_name: true
camera_view: auto
type: picture-entity
camera_image: camera.entrance
tap_action:
action: call-service
service: camera.turn_on
data: {}
entity_id: camera.doorbell
- type: conditional
conditions:
state: streaming
card:
type: vertical-stack
cards:
- show_name: true
show_icon: false
type: button
tap_action:
service: camera.turn_off
data: {}
entity: camera.entrance
- type: custom:webrtc-camera
Close edit mode. Then try it out.
You’re meant to click/tap on the image to start the stream (that’s what the tap_action
part of the YAML is about).
i got the same issue
you have the same doorbell?
not sure which one do u have
You are really doing your best to help
