I’ve added my door lock using the Eufy Security integration. I can see the entities in Home Assistant, but I’m unable to Lock or Unlock the door.
When I click on one of the actions I get the following error:
Failed to call service lock/unlock. {‘type’: ‘result’, ‘success’: False, ‘messageId’: ‘device.set_property.c4220f1e3731483e9818ee9ec24bbfb6’, ‘errorCode’: ‘unknown_error’}
I’ve added the lock to the Eufy app and shared it with the account I use for Home Assistant. I have a doorbell working this way as expected. Anything I’m missing to get the door lock to work?
Do these help? I just replaced my IP in the below.
• eufysecurity.ts:422 <anonymous>
node_modules/eufy-security-client/src/eufysecurity.ts:422:113
• node:events:513 emit
node:events:513:28
• station.ts:549 onParameter
node_modules/eufy-security-client/src/http/station.ts:549:14
• station.ts:69 <anonymous>
node_modules/eufy-security-client/src/http/station.ts:69:97
node:events:513:28
• session.ts:1564 handleDataControl
node_modules/eufy-security-client/src/p2p/session.ts:1564:38
• session.ts:1145 handleData
node_modules/eufy-security-client/src/p2p/session.ts:1145:18
• session.ts:1132 parseDataMessage
node_modules/eufy-security-client/src/p2p/session.ts:1132:26
2023-01-05 23:23:47.455 INFO Disconnected from station T8010P13203624D7
2023-01-05 23:23:52.647 INFO Connected to station T8010P13203624D7 on host 192.000.00.00 and port 28308
2023-01-05 23:24:44.105 WARN Station T8520Q252235030E - Heartbeat check failed. Connection seems lost. Try to reconnect...
2023-01-05 23:24:44.106 INFO Disconnected from station T8520Q252235030E
2023-01-05 23:24:51.702 INFO Connected to station T8520Q252235030E on host 192.000.00.00 and port 23393
2023-01-05 23:24:51.946 ERROR Update device properties error
DeviceNotFoundError Device with this serial doesn't exists!
error stack:
• eufysecurity.ts:349 getDevice
node_modules/eufy-security-client/src/eufysecurity.ts:349:15
• eufysecurity.ts:709 updateDeviceProperties
node_modules/eufy-security-client/src/eufysecurity.ts:709:14
node:events:513:28
node:events:513:28
• session.ts:1563 handleDataControl
node_modules/eufy-security-client/src/p2p/session.ts:1563:38
2023-01-05 23:24:51.951 ERROR Update device properties error
error stack:
node:events:513:28
node:events:513:28
2023-01-05 23:24:56.202 INFO Disconnected from station T8010P13203624D7
2023-01-05 23:25:01.378 INFO Connected to station T8010P13203624D7 on host 192.000.00.00 and port 18060
Did you end up getting any info on this? I just tried to update from 2.9.0 to 6.1.1 and the same thing happened to me and I had to go back to 2.9.0
Unfortunately not. Still not too sure why my other devices seem to work, but for whatever reason I can’t lock/unlock this one. I can see it and even get the battery level.
joekingmo
(Joe King)
January 11, 2023, 10:46pm
6
Kind of same problem with the EUFY Doorbell camera now, i disconnects and connects from station constantly.
I’ve still had no luck, but noticed your issue has been marked as closed
