Eurom E-convect WiFi
I was hoping my Designheat 2000 could use the Tuya climate as well, but alas:
[18:16:28][C][tuya:041]: Tuya:
[18:16:28][C][tuya:044]:   Initialization failed. Current init_state: 0
[18:16:28][C][tuya:049]:   If no further output is received, confirm that this is a supported Tuya device.
[18:16:29][D][api.connection:1446]: Home Assistant 2025.1.4 (192.168.68.14): Connected successfully
[18:16:29][D][time:050]: Synchronized time: 2025-02-02 18:16:29
[18:16:39][E][tuya:464]: Initialization failed at init_state 0
[18:16:54][E][tuya:464]: Initialization failed at init_state 0
I also get this output from my recently flashed ESP8266 chip…so does this technically mean we cannot use UART? I am trying to use the climate.tuya platform:
[03:46:42][C][tuya:041]: Tuya:
[03:46:42][C][tuya:044]:   Initialization failed. Current init_state: 0
[03:46:42][C][tuya:049]:   If no further output is received, confirm that this is a supported Tuya device.
[03:46:43][V][tuya:438]: Sending Tuya: CMD=0x00 VERSION=0 DATA=[] INIT_STATE=0
[03:46:43][D][uart_debug:114]: >>> 55 AA 00 00 00 00 FF
[03:46:44][V][tuya:438]: Sending Tuya: CMD=0x00 VERSION=0 DATA=[] INIT_STATE=0
[03:46:44][D][uart_debug:114]: >>> 55 AA 00 00 00 00 FF
[03:46:45][D][uart_debug:114]: >>> 55 AA 00 00 00 00 FF
[03:46:45][E][tuya:464]: Initialization failed at init_state 0
hi drbytes,
Can you please help me on how you have deleted the very loud beep?
I just bought the same heater (Eurom Sani-Wall-Heat 2000 Wifi) and I’m, like you, very annoyed by it.
Thanks!
Bas (Mr.)
Easy. I used a dap of hot snot (glue gun) on the hole of the speaker :slight_smile:
