Eurotronic Air Quality Sensor (Z-Wave) compatible with z-wave js / Anyone integrated it successfully?
I´m looking for an Air Quality Sensor and found this one quite interesting:
https://eurotronic.org/produkte/sensoren/co2-sensor/
It is not in the Zave-Js device list (https://devices.zwave-js.io/), so I´m not sure if it able to integrate into Home Assistant.
Was anyone able to make it work with Home Assistant?
Looks like you posted the wrong link, the Z-Wave version is Luftgütesensor Z-Wave Plus (VOC Sensor) | EUROTRONIC Technology GmbH
It looks like pretty standard Z-Wave functionality. There shouldn’t be any issues with Z-Wave JS. The only one that might be an issue is the presence of Transport Service CC v2, which is partially supported in Z-Wave JS. The receiving of TS messages is implemented, that’s probably the important part.
Otherwise, what will be missing are the device description (product name) and configuration parameters. The configuration parameters are well documented, so it’d be fairly easy to create a config file. All the notifications and multilevel sensor values are standard Z-Wave.
Oh, sorry, I posted the wrong link. Of course it is the z-wave plus version I requested help for.
As it should be working in general, I ordered one.
I post my experience with it later in the forum.
Maybe I´m able to create an according config file. We will see.
@Toffi
can you share how does it work?
@Toffi any idea? thanks!
Hi, sorry for the delay. Yes it worked. First I tried a secure integration, which did not work. But unsecure - OK for me - worked flawless.
Hey @Toffi have you been happy with the sensor?
Hi, yes, it is working fine with ZHA.
Great, thanks for the info! Will consider the sensor, looking for a CO2 sensor for controlling ventilation in our house.
@Toffi
I am still a little beginner. Today I also got the Eurotronic air quality sensor. How can I add this? Eurotronic is not shown to me in the list?!?
Sorry for my late reply. As I wrote earlier, the device integration in Z-Wave JS Integration worked flawless, when selecting the non-secure type of communication. I get the above sensors in HA.
Of course, the integration of a new Z-Wave device needs an active inclusion process initiated by the user/you. But this is general for Z-wave. Nothing special for this device.
