EUROtronic Comet Z-Wave
I would like to know if this work out of box even without full support without a component for this device ?
Link to Device (Website in english)
https://www.eurotronic.org/en/products/comet-z-wave.html
or if maybe someone could do the work and add it for next release to HASS.
I don’t have any here yet so I can’t give logs or something else.
I don’t see it here: https://github.com/OpenZWave/open-zwave/tree/master/config so even though it will probably work it will show as “unknown device”.
I think this is config for that thermostat https://github.com/OpenZWave/open-zwave/blob/master/config/eurotronic/eur_cometz.xml It should work but You will be sure if You buy one and test it.
I have one of those and it worked out of the box.
It has a pretty strange setup process, you should read the manual before connecting it.
The connect button is inside the battery compartment and pretty hard to reach.
All in all a pretty cheap but reliable thermostat with a pretty high battery consumption.
Well that seems nice at least. How is the battery life for these ?
