EUROtronic EUR_SPIRITZ radiator valves
I have a Zwave setup with a ZWAVE.me USB dongle. I’m still quite new to home assistant but have added a few devices to my zwave network and they seem to work sofar. (I’m moving everything from Homey to HomeAssistant btw).
Next up my list was moving my radiator valve, the EUROtronic EUR_SPIRITZ variant. I’m aware of the issues of sporadic mallfunction and having blody hot rooms (had that with Homey too) but so far I’m unable to set the target temperature.
In my thermostat_mode entity I’m not seeing anything for setting the target temperature. The text is there but now input field. Lovelace shows the temperature dial grayed out so it’s not supporting it.
With the Zwave log open, I notice that when I change the Operation mode to “Heat” that is actually communicated to the valve, and I hear the motor turning, but within a second the UI flips back to Off. So somehow HA is not accepting the new state or thinks it failed or something.
2020-10-21 21:06:10.103 Info, Node007, Value::Set - COMMAND_CLASS_THERMOSTAT_MODE - Mode - 0 - 1 - Heat
2020-10-21 21:06:10.104 Detail, Node007, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_THERMOSTAT_MODE
2020-10-21 21:06:10.104 Detail, Node007, Queuing (Send) ThermostatModeCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x40, 0x01, 0x01, 0x25, 0x44, 0xc3
2020-10-21 21:06:10.104 Detail, Node007, Queuing (Send) ThermostatModeCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x40, 0x02, 0x25, 0x45, 0xc2
2020-10-21 21:06:10.104 Info, Node007, Processing (Send) Nonce Request message (Callback ID=0x44, Expected Reply=0x13)
2020-10-21 21:06:10.104 Info, Node007, Sending (Send) message (Callback ID=0x44, Expected Reply=0x13) - Nonce_Get(ThermostatModeCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-10-21 21:06:10.111 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-21 21:06:10.111 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2020-10-21 21:06:11.366 Detail, Node007,   Received: 0x01, 0x18, 0x00, 0x13, 0x02, 0x00, 0x00, 0x7d, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x04, 0x00, 0x00, 0x04
2020-10-21 21:06:11.366 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-10-21 21:06:11.366 Info, Node007, Request RTT 1261 Average Request RTT 752
2020-10-21 21:06:11.390 Detail, Node007,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x07, 0x0a, 0x98, 0x80, 0x58, 0xc6, 0x42, 0xa3, 0xe1, 0xe0, 0x7c, 0x9f, 0xca, 0x00, 0xab
2020-10-21 21:06:11.390 Info, Node007, Received SecurityCmd_NonceReport from node 7
2020-10-21 21:06:11.391 Info, Node007, Sending (Send) message (Callback ID=0x46, Expected Reply=0x13) - ThermostatModeCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x40, 0x01, 0x01, 0x25, 0x46, 0xc1
2020-10-21 21:06:11.401 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-21 21:06:11.401 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2020-10-21 21:06:11.429 Detail, Node007,   Received: 0x01, 0x18, 0x00, 0x13, 0x46, 0x00, 0x00, 0x03, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x7b
2020-10-21 21:06:11.429 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x46 received (expected 0x46)
2020-10-21 21:06:11.429 Info, Node007, Request RTT 1324 Average Request RTT 1038
2020-10-21 21:06:11.429 Detail,   Expected callbackId was received
2020-10-21 21:06:11.429 Detail,   Expected reply was received
2020-10-21 21:06:11.429 Detail,   Message transaction complete
2020-10-21 21:06:11.429 Detail, Node007, Removing current message
2020-10-21 21:06:11.430 Detail,
2020-10-21 21:06:11.430 Info, Node007, Processing (Send) Nonce Request message (Callback ID=0x45, Expected Reply=0x04)
2020-10-21 21:06:11.430 Info, Node007, Sending (Send) message (Callback ID=0x45, Expected Reply=0x04) - Nonce_Get(ThermostatModeCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-10-21 21:06:11.436 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-21 21:06:11.436 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2020-10-21 21:06:11.460 Detail, Node007,   Received: 0x01, 0x18, 0x00, 0x13, 0x02, 0x00, 0x00, 0x03, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x3f
2020-10-21 21:06:11.460 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-10-21 21:06:11.460 Info, Node007, Request RTT 30 Average Request RTT 534
2020-10-21 21:06:11.486 Detail, Node007,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x07, 0x0a, 0x98, 0x80, 0xea, 0x46, 0x15, 0x84, 0xcb, 0x26, 0xad, 0xa1, 0xca, 0x00, 0xea
2020-10-21 21:06:11.486 Info, Node007, Received SecurityCmd_NonceReport from node 7
2020-10-21 21:06:11.486 Info, Node007, Sending (Send) message (Callback ID=0x47, Expected Reply=0x04) - ThermostatModeCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x40, 0x02, 0x25, 0x47, 0xc0
2020-10-21 21:06:11.496 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-21 21:06:11.497 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2020-10-21 21:06:11.525 Detail, Node007,   Received: 0x01, 0x18, 0x00, 0x13, 0x47, 0x00, 0x00, 0x03, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x7a
2020-10-21 21:06:11.525 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x47 received (expected 0x47)
2020-10-21 21:06:11.525 Info, Node007, Request RTT 94 Average Request RTT 314
2020-10-21 21:06:11.525 Detail,   Expected callbackId was received
2020-10-21 21:06:11.561 Detail, Node007,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x07, 0x02, 0x98, 0x40, 0xca, 0x00, 0xe6
2020-10-21 21:06:11.561 Info, Node007, Received SecurityCmd_NonceGet from node 7
2020-10-21 21:06:11.561 Info, NONCES: 0x8b, 0x96, 0x9c, 0x1a, 0x81, 0x5b, 0x9e, 0x48
2020-10-21 21:06:11.561 Info, NONCES: 0x88, 0x5e, 0xe0, 0xb5, 0x9e, 0xc3, 0xdf, 0xc8
2020-10-21 21:06:11.561 Info, NONCES: 0x9a, 0xad, 0x42, 0x21, 0xa2, 0x26, 0xf0, 0x79
2020-10-21 21:06:11.561 Info, NONCES: 0x69, 0x9f, 0x10, 0x5c, 0xaa, 0x55, 0xcc, 0x5d
2020-10-21 21:06:11.562 Info, NONCES: 0x71, 0x4e, 0xef, 0xfa, 0xe3, 0x47, 0xf4, 0x0c
2020-10-21 21:06:11.562 Info, NONCES: 0x2a, 0xe2, 0x22, 0x26, 0xb7, 0x85, 0x3e, 0x5e
2020-10-21 21:06:11.562 Info, NONCES: 0xfd, 0xd7, 0x6d, 0xf8, 0x3b, 0xda, 0xa3, 0xc9
2020-10-21 21:06:11.562 Info, NONCES: 0x90, 0xb2, 0x5a, 0xfd, 0xce, 0xcc, 0x53, 0xc5
2020-10-21 21:06:11.562 Info, Node007, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x07, 0x0a, 0x98, 0x80, 0x8b, 0x96, 0x9c, 0x1a, 0x81, 0x5b, 0x9e, 0x48, 0x05, 0x01, 0x7b:
2020-10-21 21:06:11.569 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-21 21:06:11.569 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2020-10-21 21:06:11.595 Detail, Node007,   Received: 0x01, 0x18, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x3d
2020-10-21 21:06:11.595 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-10-21 21:06:11.595 Info, Node007, Request RTT 165 Average Request RTT 239
2020-10-21 21:06:11.627 Detail, Node007,   Received: 0x01, 0x20, 0x00, 0x04, 0x00, 0x07, 0x18, 0x98, 0x81, 0x2d, 0x10, 0x22, 0xdb, 0xe0, 0x1e, 0x50, 0x85, 0x7a, 0x62, 0x9e, 0x10, 0x67, 0x8b, 0x1c, 0x47, 0x57, 0xbf, 0x2c, 0x08, 0x12, 0x8b, 0xca, 0x00, 0x8c
2020-10-21 21:06:11.628 Info, Raw: 0x98, 0x81, 0x2d, 0x10, 0x22, 0xdb, 0xe0, 0x1e, 0x50, 0x85, 0x7a, 0x62, 0x9e, 0x10, 0x67, 0x8b, 0x1c, 0x47, 0x57, 0xbf, 0x2c, 0x08, 0x12, 0x8b, 0xca
2020-10-21 21:06:11.628 Detail, Node007, Decrypted Packet: 0x00, 0x40, 0x03, 0x01, 0x00
2020-10-21 21:06:11.628 Info, Node007, Response RTT 197 Average Response RTT 196
2020-10-21 21:06:11.628 Detail, Node007, Refreshed Value: old value=2, new value=1, type=list
2020-10-21 21:06:11.628 Detail, Node007, Changes to this value are not verified
2020-10-21 21:06:11.628 Info, Node007, Received thermostat mode: Heat
2020-10-21 21:06:11.628 Detail, Node007,   Expected reply and command class was received
2020-10-21 21:06:11.628 Detail, Node007,   Message transaction complete
2020-10-21 21:06:11.628 Detail, Node007, Removing current message
2020-10-21 21:06:11.628 Detail, Node007, Notification: ValueChanged
The device is included as a Zwave secure device. Is there anything I’ve missed?
