Hello everybody!
I’ve recently set up Eurotronic Spirit Z-Wave thermostat and Home Assistant 0.116.2.
The problem I have is that if I change the desired temperature in the UI, it’s sent to the node, but UI itself remains unchanged.
The picture below is after I set the temperature to 22 C.
I see the updated value on the LCD thermostat’s display, I also see the next lines in the logs:
2020-10-14 21:37:04.023 Info, Node006, Value::Set - COMMAND_CLASS_THERMOSTAT_SETPOINT - Heat - 1 - 1 - 22
2020-10-14 21:37:04.023 Detail, Node006, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT
2020-10-14 21:37:04.023 Detail, Node006, Queuing (Send) ThermostatSetpointCmd_Set (Node=6): 0x01, 0x0c, 0x00, 0x13, 0x06, 0x05, 0x43, 0x01, 0x01, 0x01, 0x16, 0x25, 0x2e, 0xbc
2020-10-14 21:37:04.023 Detail, Node006, Queuing (Send) ThermostatSetpointCmd_Get (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x43, 0x02, 0x01, 0x25, 0x2f, 0xa9
2020-10-14 21:37:04.023 Info, Node006, Processing (Send) Nonce Request message (Callback ID=0x2e, Expected Reply=0x13)
2020-10-14 21:37:04.023 Info, Node006, Sending (Send) message (Callback ID=0x2e, Expected Reply=0x13) - Nonce_Get(ThermostatSetpointCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-10-14 21:37:04.030 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-14 21:37:04.030 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-14 21:37:05.311 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x81, 0x68
2020-10-14 21:37:05.311 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-10-14 21:37:05.311 Info, Node006, Request RTT 1287 Average Request RTT 1930
2020-10-14 21:37:05.333 Detail, Node006, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x06, 0x0a, 0x98, 0x80, 0xc5, 0x14, 0xc2, 0xe6, 0xdd, 0x79, 0xd0, 0x84, 0xfa
2020-10-14 21:37:05.333 Info, Node006, Received SecurityCmd_NonceReport from node 6
2020-10-14 21:37:05.333 Info, Node006, Sending (Send) message (Callback ID=0x30, Expected Reply=0x13) - ThermostatSetpointCmd_Set (Node=6): 0x01, 0x0c, 0x00, 0x13, 0x06, 0x05, 0x43, 0x01, 0x01, 0x01, 0x16, 0x25, 0x30, 0xa2
2020-10-14 21:37:05.343 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-14 21:37:05.343 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-14 21:37:05.370 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x30, 0x00, 0x00, 0x04, 0xdf
2020-10-14 21:37:05.370 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x30 received (expected 0x30)
2020-10-14 21:37:05.370 Info, Node006, Request RTT 1346 Average Request RTT 1638
2020-10-14 21:37:05.370 Detail, Node006, Removing current message
2020-10-14 21:37:05.370 Info, Node006, Processing (Send) Nonce Request message (Callback ID=0x2f, Expected Reply=0x04)
2020-10-14 21:37:05.370 Info, Node006, Sending (Send) message (Callback ID=0x2f, Expected Reply=0x04) - Nonce_Get(ThermostatSetpointCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-10-14 21:37:05.377 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-14 21:37:05.377 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-14 21:37:05.398 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2020-10-14 21:37:05.398 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-10-14 21:37:05.398 Info, Node006, Request RTT 27 Average Request RTT 832
2020-10-14 21:37:05.420 Detail, Node006, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x06, 0x0a, 0x98, 0x80, 0x6f, 0xfa, 0xbb, 0x8b, 0x19, 0x1e, 0xfd, 0xcc, 0x6c
2020-10-14 21:37:05.420 Info, Node006, Received SecurityCmd_NonceReport from node 6
2020-10-14 21:37:05.420 Info, Node006, Sending (Send) message (Callback ID=0x31, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x43, 0x02, 0x01, 0x25, 0x31, 0xb7
2020-10-14 21:37:05.430 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-14 21:37:05.430 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-14 21:37:05.456 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x31, 0x00, 0x00, 0x03, 0xd9
2020-10-14 21:37:05.456 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x31 received (expected 0x31)
2020-10-14 21:37:05.456 Info, Node006, Request RTT 86 Average Request RTT 459
2020-10-14 21:37:05.492 Detail, Node006, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x06, 0x02, 0x98, 0x40, 0x2f
2020-10-14 21:37:05.492 Info, Node006, Received SecurityCmd_NonceGet from node 6
2020-10-14 21:37:05.492 Info, Node006, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x06, 0x0a, 0x98, 0x80, 0x08, 0x7e, 0x64, 0x85, 0xd5, 0x19, 0x64, 0xa8, 0x05, 0x01, 0x7a:
2020-10-14 21:37:05.500 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-14 21:37:05.500 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-14 21:37:05.523 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2020-10-14 21:37:05.523 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-10-14 21:37:05.523 Info, Node006, Request RTT 152 Average Request RTT 305
2020-10-14 21:37:05.553 Detail, Node006, Received: 0x01, 0x20, 0x00, 0x04, 0x00, 0x06, 0x1a, 0x98, 0x81, 0x8b, 0xc6, 0x17, 0xcf, 0x94, 0x6f, 0x29, 0x50, 0xec, 0x19, 0xd4, 0xcf, 0xd2, 0x4f, 0xd7, 0x08, 0xa5, 0xb0, 0x82, 0xe2, 0x81, 0xc4, 0x1a, 0x03, 0x4c
2020-10-14 21:37:05.553 Detail, Node006, Decrypted Packet: 0x00, 0x43, 0x03, 0x01, 0x22, 0x00, 0xdc
2020-10-14 21:37:05.553 Info, Node006, Response RTT 183 Average Response RTT 830
2020-10-14 21:37:05.554 Detail, Node006, Refreshed Value: old value=22.0, new value=22.0, type=decimal
2020-10-14 21:37:05.554 Detail, Node006, Changes to this value are not verified
2020-10-14 21:37:05.554 Info, Node006, Received thermostat setpoint report: Setpoint Heat = 22.0C
2020-10-14 21:37:05.554 Detail, Node006, Expected reply and command class was received
2020-10-14 21:37:05.554 Detail, Node006, Message transaction complete
2020-10-14 21:37:05.554 Detail, Node006, Removing current message
2020-10-14 21:37:05.554 Detail, Node006, Notification: ValueChanged
What can be a problem?
