I just don’t know where I can ask my question elsewhere and maybe someone is wondering too, so here we go:
I have several working SPZB0001 with zigbee2mqtt with HA.
What I don’t get is how I can configure the devices that the maximum temperature isn’t 30°C anymore.
I set the temperature through system mode and, as it is described in the docs, the device sets to Boost-Mode. But how do I achieve it to set it permanently to a different value?
If I use only the climate.set_temperature
"hvac_mode": "heat"
the device tries to heat until 30°C.
If I use
"hvac_mode": "heat",
"temperature": "16"
the device mostly sets temperature to 16°C, but it also happens that it ignores my temperature attribute and sets it to 30°C anyway.
If I use
"temperature": "16",
"target_temp_high":"22",
"target_temp_low":"15"
nothing new happens on the device; it mostly sets temperature to 16°C, but also sometimes to 30°C.
So… has anyone here an example for me how to correctly address these thermostats?
And, bonus question:
- What is the mirror mode?
The documentation of the device doesn’t give answers at all, so I hope you guys can help.
Thanks a lot!
