I am not able to figure out how to integrate all that Easee Wallbox attributes into that EV Charger card. I selected all attributes in the integration
This is my “Card config”
I understand that I have to add the attributes I would like to be shown directly in YAML but I am not understanding how to do that:
I would like to let my card look like that one from the Github of the code:
iflowmac
(Iflowmac)
August 8, 2021, 11:12am
2
i have the same problem, plz help!
thx a lot
Did any one resolve this on how to use the stats etc
I have documented my use of the statistics on the EV charger card here:
opened 08:08PM - 29 Oct 21 UTC
enhancement
help wanted
good first issue
**Is your feature request related to a problem? Please describe.**
I would like… to be able to directly control the car's charging rate. THis is now possible via the new API endpoint CHARGING_AMPS (requires vehicle 2021.36.5+).
**Describe the solution you'd like**
A number entity that lets you set the current, from 5 amps to the vehicle maximum (too tricky? Could just use 48, but some cars won't take more than 32).
**Describe alternatives you've considered**
Just calling the custom api via the below from an automation triggered by an input_number works well, but it would be nice to be able to rate limit it, check for errors etc.
```yaml
service: tesla_custom.api
command: CHARGING_AMPS
parameters:
path_vars:
vehicle_id: '{{ state_attr(''binary_sensor.<car_name>_online_sensor'', ''id'') }}'
charging_amps: 16
**Additional context**
Until now i've been using TWCManager to control the charge rate using the wall charger itself. The use case being to track solar production and charge your car using solar power exclusively. TWCManager is somewhat error prone. The codebase is a bit unstable, and it requires a hardware hack i'd just as soon eliminate if possible.
dbrunt
(Daniel)
November 7, 2022, 1:03am
5
My Wallbox is just a dumb 32A charger but using Emporia Vue2 power monitoring I now have this card…
Card yaml:
type: custom:charger-card
brand: other
entity: sensor.wallbox_32a_charger
customImage: /local/images/32A Wallbox (2).png
customCardTheme: theme_custom
chargerImage: White
show_leds: true
show_collapsibles: false
details:
name:
entity_id: sensor.wallbox_32a_charger
attribute: name
attribute: site_name
status:
statetext:
'off': Idle
'on': Charging
info_left:
- entity_id: sensor.circuit_11_power
text: power
unit_show: true
info_right:
- entity_id: sensor.household_voltage
text: voltage
unit_show: true
stats:
default:
- entity_id: calculated
calc_function: sum
calc_entities:
- entity_id: sensor.32a_car_charging_session_step_1
- entity_id: sensor.32a_car_charging_session_step_2
text: This Session
unit_show: true
unit: kWh
round: 1
calc_function: sum
calc_entities:
- entity_id: input_number.32a_car_charger_last_session_step_1
- entity_id: input_number.32a_car_charger_last_session_step_2
text: Last Session
unit_show: true
unit: kWh
round: 1
calc_function: sum
calc_entities:
- entity_id: sensor.32a_car_charger_monthly_energy_step_1
- entity_id: sensor.32a_car_charger_monthly_energy_step_2
text: This Month
unit_show: true
unit: kWh
round: 1
text: Step 1
unit_show: true
unit: kWh
round: 1
text: Step 2
unit_show: true
unit: kWh
round: 1
card_mod:
class: inline-card
When defining “round: 0”, I still get 1 digit after the comma. Is it possible to round and display to the closest integer without displaying comma values in the card?
