EV Charger current control based solar panel production, home battery state and home consumption
I want an automation to dynamically change the charger current of my EV based on Solar Panel production, home battery state and home consumption. Hopefully someone can give an idea how to create this.
My solar panel system is limited to 5 kW.
My idea is to give priority to my home battery to charge from the solar system. Once the battery is full, my car may start to charge but ideal it should only use the solar panel consumption and not from the grid.
All entities and services are in Home Assistant but I don’t know how to make the automation.
Home Battery State / 0 till 100 %: sensor.battery_state_of_capacity
Solar Power Production / 0 till 5000 W: sensor.inverter_input_power
Home consumption: sensor.pv_home_usage
Service to set max charge of car: Easee EV Charger: Set charger max limit 0 till 32 A (0 till 7000 Watt)
My inverter is limited to 5000 W so if the total consumption is 6000 Watts and my Home Battery is full, it will take 1000 W from the grid. Also something I’d like to avoid.
Here’s a script for a tesla charger pulling data from a Neurio with direct access to the car’s commands. You might be able to extract some ideas from it. Runs in Bash.
I made it myself - plan is to package it up at some time but at the moment all is done with several Helpers and automation scripts. Happy to share them with you but it will be some work to get it going.
Thanks but I don’t have a Tesla. I drive with a VW ID4.
Would be very helpfull if you can share ‘your project’. I’ve posted also on Facebook and some guys came up with integrations that will do this job but they don’t support HA entities so that means I have to do difficult things with serial connections and/or IP related data. I’m not a specialist in that so I prefer to use the HA entities
I know. I wrote that script for my personal needs. You might be able to tailor it for your use when you figure out how to interface with your car.
I use node red for my house battery and ev charging, I just use the granny charger as I can switch it on and off with a smart plug and it only draws 2.3kw max, so during the day once my house battery is charged if I turn the EV charger on it will charge until the house battery drops to 93% as my inverter won’t start charging the house battery again after it has hit 100% until it goes below 94%. I have an auto charge at night setting as I get cheap night power, but aim to create a day charge function so it will look after itself but at the moment it’s manual.
You can find the automations i am using in the git repo here: GitHub - gsaurer/ha-ems: Energy managemnt system for Home Assistant keep in mind that you need several helpers to get those scripts going. I will try to package it up more cleanly in the next couple of weeks.
The automations are triggered based on power sensors, battery sensors and are directly telling the ev charging station (in my case go-e) with how much Amps it should charge.
Let me know if you have any questions.
i have the same Inverter 5k and after 5000W it uses Grid, so i added 2,2Kwp more on the roof and used a grid tied inverter on the generator/microinverter port. the power from that wort is AC and so it is added on Top of the 5000W. Works perfect for me since 2 month.
For setting the EV charge Amps i plan to write an automation next few weeks.
Have a Feyre (Tuya) charger and an Renault Twingo.
Hi gsaurer, thank you for your great job, I have an electric car and off grif photovoltaic, I only feed myself with the sun and batteries, I would like to integrate your automations that solve the problem of constantly checking and manually changing the amps. Would you be so kind as to share the helpers and scripts?
Took me some time but you can now download the blueprint from here: ha-ems/blueprints/EMS-Car-SurplusCharging.yaml at main · gsaurer/ha-ems · GitHub
I will publish it to the blueprint community in the coming days along another automation that set’s the charging based on calendar entries to make sure you have enough energy to travel where you want.
Hy Gsaurer,
Thanks a lot, this sounds perfect for me.
I tried the integration but I’m not sure if I did everything correct.
I’m a HA newbie and don’t know exactly how all of this works together but it seems that I enabled the blueprint but I’m not sure if it works.
I have my PV up and running in HA and also the easee home EV charger is integrated, not sure how the blueprint can now start the charging because the easee charger can only be startet via a service and not with changeing the state of the charger.
Any feedback would be great.
Hello, i would be very interested how you managed to modulate charging on a tesla with HA. Where can i find your script & setup?
Hi, scripts can be found under the link above ha-ems/blueprints/EMS-Car-SurplusCharging.yaml at f8b6e13d8308f23f62e78cadb2d5a935a3c61d7f · gsaurer/ha-ems · GitHub
I built a similar priority flow last year — home battery first, then EV, then grid-export as overflow. The trick with dynamic charging is matching the car’s step resolution to your panel delta: if your charger only accepts 1A steps (6A minimum on most EVs) you can only follow production to ~1.4kW granularity, which means you’ll constantly overshoot/undershoot with a 5kW array. Two things helped: a 3-minute rolling average on production + a dead-band around the current target (±100W) so the charger doesn’t flip every 30 seconds. Also worth checking if your EV supports phase switching — gained me ~12% effective range during shoulder seasons. One more thing on sizing — if you ever expand beyond 5kW, the price-per-watt sweet spot right now is firmly in the 400 watt solar panels class rather than older 330W modules: fewer strings to manage and cleaner wiring. Happy to share the HA automation YAML if you want.
