Charge logic:
[{"id":"3e69cdaf73117960","type":"tab","label":"Charge on logic","disabled":false,"info":"","env":[]},{"id":"640730e15ac8308f","type":"api-current-state","z":"3e69cdaf73117960","name":"","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.charge_at_night_schedule","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":310,"y":280,"wires":[["d5e983d821b83bad"],["37fe8108339c41c4","8adb93a631a3cbe8","8a47a19ca145f6c3","31ce5a6452e8a6a6"]]},{"id":"edac062ec8c65a2e","type":"api-current-state","z":"3e69cdaf73117960","name":"Battery >=?%","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"$number(\t $entities(\"input_number.stop_charging_at_battery_percentage\").state\t)\t","halt_if_type":"jsonata","halt_if_compare":"gte","entity_id":"sensor.battery_state_of_charge","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":620,"y":580,"wires":[["69ae13bada2c89ec"],[]]},{"id":"d5e983d821b83bad","type":"time-range-switch","z":"3e69cdaf73117960","name":"19:00-07:00","lat":"51.16054","lon":"4.6485","startTime":"19:01","endTime":"07:01","startOffset":0,"endOffset":0,"x":670,"y":280,"wires":[["37fe8108339c41c4","8adb93a631a3cbe8","8a47a19ca145f6c3","31ce5a6452e8a6a6"],["84266b72acf4a5db"]]},{"id":"8a47a19ca145f6c3","type":"api-current-state","z":"3e69cdaf73117960","name":"","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.only_charge_from_battery","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":250,"y":580,"wires":[["edac062ec8c65a2e"],[]]},{"id":"514bb4f2744ee319","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1070,"y":620,"wires":[["c0b5d5d30dfbbd83"]]},{"id":"31ce5a6452e8a6a6","type":"api-current-state","z":"3e69cdaf73117960","name":"","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.only_charge_with_full_battery","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":320,"y":700,"wires":[["9b24b931347d780c"],[]]},{"id":"9b24b931347d780c","type":"api-current-state","z":"3e69cdaf73117960","name":"Battery >=96%","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"96","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.battery_state_of_charge","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":680,"y":700,"wires":[["c53bebd0c6bc9449"],[]]},{"id":"2be8becef398085f","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1190,"y":780,"wires":[["c0b5d5d30dfbbd83"]]},{"id":"615e4fcebe049208","type":"api-current-state","z":"3e69cdaf73117960","name":"","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.charge_when_connected","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":320,"y":180,"wires":[["a34d2937afd18c16"],[]]},{"id":"a34d2937afd18c16","type":"api-current-state","z":"3e69cdaf73117960","name":"Wallbox Unavailable?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"Unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.wallbox_portal_pause_resume","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":680,"y":180,"wires":[[],["40fb6d6ab472f564"]]},{"id":"40fb6d6ab472f564","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":910,"y":180,"wires":[["c0b5d5d30dfbbd83"]]},{"id":"37fe8108339c41c4","type":"api-current-state","z":"3e69cdaf73117960","name":"","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.charge_long_interval","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":290,"y":420,"wires":[["316fff4bc9f3f0ba"],[]]},{"id":"316fff4bc9f3f0ba","type":"api-current-state","z":"3e69cdaf73117960","name":"Interval 20 > 0.5?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"0.5","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.nordpool_diff_interval_20","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":630,"y":420,"wires":[["00e38cfb26f19e37"],[]]},{"id":"00e38cfb26f19e37","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":930,"y":420,"wires":[["c0b5d5d30dfbbd83"]]},{"id":"025eba556e0f115c","type":"inject","z":"3e69cdaf73117960","name":"Inject 30s","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"30","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":130,"y":80,"wires":[["afe72b3375754982"]]},{"id":"afe72b3375754982","type":"delay","z":"3e69cdaf73117960","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":300,"y":80,"wires":[["b354759ee335037d"]]},{"id":"8adb93a631a3cbe8","type":"api-current-state","z":"3e69cdaf73117960","name":"","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.charge_short_interval","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":290,"y":480,"wires":[["9daaeb0eb34917f7"],[]]},{"id":"9daaeb0eb34917f7","type":"api-current-state","z":"3e69cdaf73117960","name":"Interval 6 > 0?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.nordpool_diff_interval_6","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":620,"y":480,"wires":[["8f0d81d271476fc4"],[]]},{"id":"8f0d81d271476fc4","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":950,"y":480,"wires":[["c0b5d5d30dfbbd83"]]},{"id":"a65f19fbcded465a","type":"delay","z":"3e69cdaf73117960","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1020,"y":80,"wires":[["9bf4f1e8a804fa95"]]},{"id":"c0b5d5d30dfbbd83","type":"change","z":"3e69cdaf73117960","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":320,"wires":[["a65f19fbcded465a"]]},{"id":"84266b72acf4a5db","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge off","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":870,"y":340,"wires":[[]]},{"id":"b354759ee335037d","type":"api-current-state","z":"3e69cdaf73117960","name":"Wallbox Ready? (= not connected)","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"Ready","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.wallbox_portal_status_description","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":540,"y":80,"wires":[["a25411b7fce0f702"],["a65f19fbcded465a","615e4fcebe049208","640730e15ac8308f"]]},{"id":"a25411b7fce0f702","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge off","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":930,"y":20,"wires":[[]]},{"id":"69ae13bada2c89ec","type":"api-current-state","z":"3e69cdaf73117960","name":"Charge is off?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.charge","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":740,"y":640,"wires":[["5d112a199befc150"],["514bb4f2744ee319"]]},{"id":"5d112a199befc150","type":"api-current-state","z":"3e69cdaf73117960","name":"Battery >=27%","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"$number(\t $entities(\t \"input_number.stop_charging_at_battery_percentage\"\t ).state\t)+7","halt_if_type":"jsonata","halt_if_compare":"gte","entity_id":"sensor.battery_state_of_charge","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":860,"y":560,"wires":[["397e79a20c316e03"],[]]},{"id":"397e79a20c316e03","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1050,"y":560,"wires":[["c0b5d5d30dfbbd83"]]},{"id":"c53bebd0c6bc9449","type":"api-current-state","z":"3e69cdaf73117960","name":"Charge is off?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.charge","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":760,"y":760,"wires":[["645bf126dd182a76"],["2be8becef398085f"]]},{"id":"645bf126dd182a76","type":"api-current-state","z":"3e69cdaf73117960","name":"Battery >=99%","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"99","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.battery_state_of_charge","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":940,"y":700,"wires":[["516ae73dca691dde"],[]]},{"id":"516ae73dca691dde","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1150,"y":700,"wires":[["c0b5d5d30dfbbd83"]]},{"id":"9bf4f1e8a804fa95","type":"api-call-service","z":"3e69cdaf73117960","name":"Charge off","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.charge"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1230,"y":80,"wires":[[]]},{"id":"f610b696.ce7818","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Wallbox switch:
[{"id":"3de22918c63c2f60","type":"tab","label":"Wallbox on/off","disabled":false,"info":"","env":[]},{"id":"f14b893e615127cf","type":"api-current-state","z":"3de22918c63c2f60","name":"Aan het laden?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.wallbox_portal_pause_resume","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"milliseconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":620,"y":120,"wires":[[],["cf1458bd1c027aca"]]},{"id":"cf1458bd1c027aca","type":"switch","z":"3de22918c63c2f60","name":"Unavailable? Wallbox","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"unavailable","vt":"str"},{"t":"neq","v":"unavailable","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":840,"y":120,"wires":[[],["bbfd23f57d3439e0"]]},{"id":"1acbd3f2406d3620","type":"api-current-state","z":"3de22918c63c2f60","name":"Aan het laden?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.wallbox_portal_pause_resume","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"milliseconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":620,"y":180,"wires":[["65825307f9fa0f3a"],[]]},{"id":"65825307f9fa0f3a","type":"api-call-service","z":"3de22918c63c2f60","name":"Wallbox off","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.wallbox_portal_pause_resume"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":950,"y":200,"wires":[[]]},{"id":"bbfd23f57d3439e0","type":"api-call-service","z":"3de22918c63c2f60","name":"Wallbox on","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wallbox_portal_pause_resume"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1050,"y":120,"wires":[[]]},{"id":"a7b451b6423faa0f","type":"delay","z":"3de22918c63c2f60","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":420,"y":120,"wires":[["f14b893e615127cf"]]},{"id":"9df9726fe6b73087","type":"delay","z":"3de22918c63c2f60","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":440,"y":180,"wires":[["1acbd3f2406d3620"]]},{"id":"a10f4cde57790669","type":"inject","z":"3de22918c63c2f60","name":"30s","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"30","crontab":"","once":true,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":90,"y":160,"wires":[["4a1d3639ab25fd14"]]},{"id":"4a1d3639ab25fd14","type":"api-current-state","z":"3de22918c63c2f60","name":"Charge on/off?","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.charge","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":240,"y":160,"wires":[["a7b451b6423faa0f"],["9df9726fe6b73087"]]},{"id":"f610b696.ce7818","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Schedule:
[{"id":"aeeb910c928b1184","type":"tab","label":"Automatic charging schedule","disabled":false,"info":"","env":[]},{"id":"db307551baf8511c","type":"inject","z":"aeeb910c928b1184","name":"Inject weekday 1/min","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"*/1 0-23 * * 1,2,3,4,5","once":true,"onceDelay":"5","topic":"","payload":"","payloadType":"date","x":200,"y":180,"wires":[["327f7c958e782bb9"]]},{"id":"c726b31e319cbd0c","type":"inject","z":"aeeb910c928b1184","name":"Inject weekend 1/min","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"*/1 0-23 * * 6,0","once":true,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":220,"y":460,"wires":[["2fab2cf710156d8b"]]},{"id":"d8fd2f88530ff283","type":"api-current-state","z":"aeeb910c928b1184","name":"Automatic schedule on","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.automatic_charging_schedule","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":200,"y":240,"wires":[["142777d01278f080","0d547b5d64084f7b"],[]]},{"id":"327f7c958e782bb9","type":"delay","z":"aeeb910c928b1184","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":400,"y":180,"wires":[["d8fd2f88530ff283"]]},{"id":"142777d01278f080","type":"api-call-service","z":"aeeb910c928b1184","name":"Off: long interval, when connected, full battery, only from battery","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.charge_long_interval","input_boolean.charge_when_connected","input_boolean.only_charge_from_battery","input_boolean.only_charge_with_full_battery"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":570,"y":240,"wires":[[]]},{"id":"0d547b5d64084f7b","type":"api-call-service","z":"aeeb910c928b1184","name":"On: at night, short interval","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.charge_short_interval","input_boolean.charge_at_night_schedule"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":450,"y":300,"wires":[[]]},{"id":"2fab2cf710156d8b","type":"delay","z":"aeeb910c928b1184","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":440,"y":460,"wires":[["047d514c94b511f8"]]},{"id":"047d514c94b511f8","type":"api-current-state","z":"aeeb910c928b1184","name":"Automatic schedule on","server":"f610b696.ce7818","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.automatic_charging_schedule","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":240,"y":520,"wires":[["8f5178e93efba710","dbd773f441881490"],[]]},{"id":"8f5178e93efba710","type":"api-call-service","z":"aeeb910c928b1184","name":"Off: long interval, short interval, when connected, at night, only from battery","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.charge_long_interval","input_boolean.charge_short_interval","input_boolean.charge_when_connected","input_boolean.charge_at_night_schedule","input_boolean.only_charge_from_battery"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":520,"wires":[[]]},{"id":"dbd773f441881490","type":"api-call-service","z":"aeeb910c928b1184","name":"On: Only charge with full battery","server":"f610b696.ce7818","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.only_charge_with_full_battery"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":510,"y":580,"wires":[[]]},{"id":"f610b696.ce7818","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Remarks, advice, questions, … feel free to reply!
