EV Smart charging with dynamic energy prices in the EU
I would like to share my enthusiasm about the HACS integration EV Smart Charging.
I have a BMW EV and a Webasto wallbox. I want to minimize my electricity bill by taking advantage of dynamic electricity prices (in the EU).
Looking for ways to do that I discovered the EV Smart Charging integration. And it is amazing.
EV Smart Charging can use one of three sources for the ‘day ahead prices’. I use the ENTSO-e Transparency Platform integration for this.
You can configure how to read the current and target SoC for your EV. In my situation I use the BMW Connected Drive integration for that.
You can configure how to detect whether the EV is connected to the wallbox. In my case I have used the Modbus integration to control the Webasto Unite wallbox. I use this to check whether the EV is connected and the session is authorized.
You can configure how start and stop the charging process. In my case I use the BMW Connected Drive for this.
I now have this operational for the normal use case: charge the EV to the fixed target SoC (80%) each time the car is @home. Taking into account todays and tomorrows prices.
I have bought a Raspberry Pi to run this on. And managed to keep the power consumption of the ‘always on’ Raspberry Pi down to 1 or 2 watts. Otherwise I would not save any cost by using this.
Currently I’m trying to add a simple interface to manually override this process for use cases:
  • I need the EV charged the day after tomorrow, because I’m working at home tomorow.
  • I need the EV charged immediately now and after that optimize for cost again.
  • I need the EV charged to 100% SoC once because I need to make a long trip. And after that revert to the safe target SoC of 80% again.
For this I will be using the HA companion App on my smartphone.
Set up https access for extra security by encrypting and thus protecting the HA credentials.
Added the Wireguard addon to create a VPN from the internet to HA.
With this setup I can use the App to control the charging from a simple dashboard with some buttons for the different use cases. Hopefully so simple that my home mate can also use this :wink:
So if you have an EV and want to optimize your charging costs, give this I try.
My ‘business case’ is as follows:
  • I pay €0.40 per kWh on a public charger (11kW)
  • I pay €0.30 per kWh at home with a fixed tarif contract
  • I pay €0,20 per kWh at home with a dynamic tarif contract. Ofcourse on average.
    To get this benefit al the time, I have spent €150 on my HA equipment
    So give it a go as well.
What a cool write-up of what you have been able to achieve. I am really impressed!
I came across this as I own a BMW iX3 and I have been trying to control the charging of my EV.
I was able to get the Day Ahead prices and was able to connect with BMW connect drive. As I don’t have access to the charger itself (it’s company owned), I tried now to control the charging as well through BMW Connected Drive, but unfortunately that does also not work.
When looking in Settings | Devices & service, tab Integration. In the tile ‘BMW Connected Drive’ click on ‘1 device’ to show your BMW.
Do you see something like this:
The third entry from the top ‘Charging’ can be used to start or stop charging. If you toggle this switch (and than click somewhere else on the screen to activate the change). Can you see that it will start charging? It takes at least 15 seconds before you see the response.
This will be visible in the Sensors section:
In the sensor ‘Charging status’.
(Note: I have three sensors shown. This is caused by updates of this Integration. But they are alle the same sensor).
Another thing is the ‘Charging Mode’. If that is not ‘Immediate charging’, the start of charging might be delayed. This is visible in the My BWM App on your smartphone.
Thanks for explaining @BrainDra1n. I was only now able to check after the issues with BMW Connected Drive in HA. Unfortunately, I don’t have the “charging” option. I can only change the charging mode. This seems to be the case for the ix3.
As far as I know the Connected Drive integration uses the API that is also used by BMW smartphone app. In the BMW app do you have an option to start charging?
If so, you can contact the developers.
See:
Maybe they can than add this option for the ix3 as well
Apparently, it has to do with the BMW OS version. Versions 7 like mine us using don’t support. A pity.
Use “Charging Mode” to control the charging cycle. First configure “Delayed charging” for a rediculous short time period (eg.: 00:00 till 00:01). You can now use “Immediate Charging” as “charge ON” and “Delayed Charging” as “charge OFF”.
Is this the way you are effectively using it in your automations?
yes indeed. Works fine for me.
Hi everyone.
I have homeassistant and I want to dynamically charge my ev changing the charging power.
I am using 1 shelly em to measure the total home energy consumption (including ev) and the ev charger app gives me the ev consumption.
I have a 6.9kVA power contract at home and I want the ev tô use only the gap between the contracted power and the rest of the house consumption (except ev).
How do I do that?
Could you give an example of how you do this? The reason I ask is that in my experience you also need to set a departure target (in the format of a concrete date and time), which can only be set in the BMW app. This gives some weird experience as the app will always override the charging mode if the departure target is sooner than the charging window. I guess it does this to make sure the battery is always full.
Just set departure time weekly, the chosen time doesn’t matter.
First of all thanks for sharing this integration. I installed this yesterday and got it working with our VW ID.3 right away.
As I’ve not been able to integrate the Ctek Njord charger I’m controlling the car directly with this integration and this got me thinking this will to my understanding be active all the time regardless of the cars location.
Would it be possible to only run this integration if the cars location is “Home” and if charging elsewere than at Home this would disable this integration?
I used the status of the charger (wallbox) to determine if the car is connected (and thus at home). For me this is a guarantee because I need to authenticate using an RFID tag.
Maybe the VW integration has a sensor/device_tracker that tells whether to car is at home. The BMW Connected Drive integration has such a device_tracker. But beware of timing issues. The BMW integration always lags behind at least 15 seconds.
Thanks for sharing! Manage to get it work for my setup (Easee + Telsa), both use cloud based API so I have some reliability issues. For example the max SoC level sometimes becomes unavailable and I can’t seem to hard code the value.
Also a question: how does low price charge work (switch.ev_smart_charging_low_price_charging)? Looks like it doesn’t plan for it but instead get triggered in realtime when price is low. What happens if next hour price is high again? Does it stop charging even though continuous charging is preferred?
What I’d want is to plan the charge with consideration of low price. I set completion time to 7:00 (so the car should be ready at 7AM tomorrow morning), if I connect in the morning, it shouldn’t wait for tomorrows el price if it knows in the afternoon the price is already below threshold. Is it possible to achieve this?
Many thanks :pray:
