EV wall charger that supports Home Assistant - Adjust wattage
Hello, I have to thank you every day, using your integration.
I made the update you made a few day ago (line 373…)
But this morning, my integration is not running at all…
Same for you?
thank you!
Came back alone!
What 3phase 11kW minimum would you recommend in 2024? I did not find that version of Duosida…
I’m doing this too, for about 3.5 years. Still everything works fine.
Using a rated up to 3680W zigbee-smartplug for it.
Charger can be configured to 8A/10A/13A/16A but with a button. It usually is setup for 13A.
To make sure there is a minimum ‘charge time’, my rules to start/stop are related to the home-battery (I have one attached to the inverter) - e.g. start the charger at 80% SoC of the house, and stop below 65% of house SoC. Any cloud/short term rise of fall of solar production is ‘smoothed’ via the home-battery. If I have way more solar than the charger takes, the house SoC goes up too.
I do have alternative rules for winter, as the house SoC would never reach high enough. In that case, I prefer to monitor “grid usage” to disable when the house is consuming a lot (e.g. we are cooking).
Anyone else here latch onto the car being a “he”? :rofl: All my cars are “she/her” pronouns. Lol sorry
Aside from that. I’ve seen a few chargers mentioned in this thread. Which one is the easiest to integrate?
I have a couple chargers listed in my blueprint, both are integrated straightforward into Home Assistant
You can check it out here: 🚗 Tesla Dynamic Charging (Ford, Mercedes… any EV) Automation
I’ll soon be getting a duosida wallbox with 22kW. Does anyone have experience with the Home Assistant integration and 400v connection?
Can the charging power be limited to 10 kW, for example, so that it cannot be accidentally changed in the app/integration?
The EmonEVSE has been discontinued :sob:
I installed my Duosida Wallbox (22 kW 3 fases), the app, and the duosidaEV home assistant integration.
First impression is very good. start/stop, change of charging power works fine.
What is the function of this switch?
switch.duosida_leveldetection
The app is in german and the translation is poor.
“Wir überprüfte CP negativ”
Manual has no information.
