Hi all,
I have a history_status counter that counts the amount of times a contact sensor closed or opened. I would like to assign a value to that, for example:
If below 5, string would be “stable”
if 10, string, would be “average”
etc
Could i do that like this:
I suspect my {% if is_state(‘binary_sensor.sensor_2_contact’,<5) %} line is not correct…also would like to know if i can do a else if
It kind of depends on how you want to map values to strings. Is it a 1-to-1 mapping? Or some range to one string, another range to another string, another range to another string, …?
Um, you have 5 associated with Stable & Average, and 20 associated with Average and Flapping, etc., and what about values above 100, so not quite sure what you want, but how about something like:
value_template: >
{% set n = states('binary_sensor.sensor_2_contact') | int %}
{% if n <= 5 %} Stable
{% elif n <= 20 %} Average
{% elif n <= 50 %} Flapping
{% else %} Alert
{% endif %}
That would work great i think, i didn’t add higher numbers just to focus on the problem at hand, but i’ll add those as well.
But what if the value is 4, would both <=5 and <= 20 or the remaining statements not also apply ? Or will the first if statement ‘break’ and get out of the if ?
And could i use 2 Words in the string or would i have to put quotes around it ?
An if - elif - else statement works by evaluating each expression in order and executing the first block whose expression evaluates to true, or the else block if none are true. And, yes, you can put whatever you want “inside” the block. If you put quotes, that will be part of the string, so don’t put quotes if you don’t want the string to contain quotes.
