I have an Eve door/window sensor (Thread/Matter) added to Apple Home.
The first time I set up Matter and added the device, it went very smooth and it worked well.
I then had to factory reset the device so I removed it from Apple Home and Home Assistant. The removal from Home Assistant was not smooth and it didn’t really leave Matter integration in a not de clean state; failed to load.
I was able to delete and reinstall the Matter integration so it looked “clean” again.
I then factory reset the Eve sensor and successfully added it back to Apple Home.
Next I tried to add it back to Home Assistant:
- Add Matter Device
- Yes, it is already in use
- Apple Home
- Enter setup code (from Apple Home)
I tried this multiple times and it keeps failing to add the device.
Thoughts?
[EDIT]
I restored a prior full backup without the Matter integration installed.
When installing the Matter integration, I am getting an error that the Matter Server add-on cannot start and the Matter integration does not show
P.S. I am now running 2024.5.3 on a RPi4.
[EDIT2]
I was able to get the Matter integration working by doing a reboot instead of a restart.
Unfortunately, I am still unable to get the device added.
