I updated my Eve Energy to Matter. It was successfully added to Apple Home.
But I can’t add it to Home Assistant.
I have tried it on Home Assistant on a Pi5 and a Home Assistant on a NUC (x86) which is a brand new installation. Both are less than 1m away from the Eve Energy.
What I did:
Open Apple Home
Click on the Eve Energy
Click on „Activate Pairing Mode“
Click on „Copy Code“
Went to Home Assistant → Integration → Add → Matter → „Already Paired“ → „Apple Home“
Paste Code
„Add Device“
→ Failed to add Device
Nyak
(Nyak)
May 18, 2024, 10:19am
2
Have you tried adding via the Matter integration?
Worked perfectly for me.
Is there another way than how I did it? If so, how?
Nyak
(Nyak)
May 19, 2024, 12:27am
4
This link should help you out.
Scroll down to the ‘Adding a Matter device to Home Assistant’ section.
But that’s exactly the way I described it and did it.
Your steps do seem correct. Do you have other devices connected to your Matter server already?
Can you try again with the latest version of the Matter Server add-on? If you still experience problems, please post the logs of the Matter Server add-on after an attempt.
Tried different Matter devices and couldn‘t connect any of them.
Will try again this weekend with the newest add-on and will post the information
Here is the error from the Matter Add-on Log:
> 2024-06-07 17:18:57.791 (Dummy-2) CHIP_ERROR [chip.native.DIS] DNSSD packet parsing failed (for SRV records)
> 2024-06-07 17:18:57.791 (Dummy-2) CHIP_ERROR [chip.native.DIS] DNSSD packet parsing failed (for non-srv records)
> 2024-06-07 17:18:58.843 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='991955F7BA726443._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
Hm, that is not a lot of log
Is this really everything from a commissioning attempt? There should be at least a info level message when commissioning starts (“Starting Matter commissioning…”).
Changed Log-Level to verbose. Here is the result:
I copied only lines which are not double/trible etc.
2024-06-07 19:54:27.675 (MainThread) WARNING [zeroconf] Error with socket 67 (('::1', 5353, 0, 0))): [Errno 101] Network is unreachable
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 1200, in sendto
self._sock.sendto(data, addr)
OSError: [Errno 101] Network is unreachable
2024-06-07 19:55:51.732 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Discovered commissionable Matter node: AsyncServiceInfo(type='_matterc._udp.local.', name='500A9645375CE188._matterc._udp.local.', addresses=[], port=5540, weight=0, priority=0, server='D6DE2FF4136A906E.local.', properties={b'VP': b'4874+80', b'DT': b'266', b'DN': b'Eve Energy', b'SII': b'800', b'SAI': b'800', b'T': b'0', b'D': b'2092', b'CM': b'2', b'RI': b'1700BE868F473977D8930EB351AE21DD1E7D', b'PH': b'36', b'PI': None}, interface_index=None)
2024-06-07 19:55:51.868 (Dummy-2) CHIP_DETAIL [chip.native.DIS] Warning: Attempt to mDNS broadcast failed on wlan0: src/inet/UDPEndPointImplSockets.cpp:416: OS Error 0x02000065: Network is unreachable
2024-06-07 19:55:51.869 (Dummy-2) CHIP_DETAIL [chip.native.DIS] mDNS broadcast had only partial success: 18 successes and 1 failures.
2024-06-07 19:55:51.880 (Dummy-2) CHIP_DETAIL [chip.native.DIS] Warning: Attempt to mDNS broadcast failed on wlan0: src/inet/UDPEndPointImplSockets.cpp:416: OS Error 0x02000065: Network is unreachable
2024-06-07 19:57:56.499 (MainThread) VERBOSE [matter_server.server.client_handler] [548168061712] Received: {
"message_id": "c9ab2316afa74c69b5b8eed54af7cc78",
"command": "commission_with_code",
"args": {
"code": "20116952115",
"network_only": true
2024-06-07 19:57:56.499 (MainThread) VERBOSE [matter_server.server.client_handler] [548168061712] Received CommandMessage(message_id='c9ab2316afa74c69b5b8eed54af7cc78', command='commission_with_code', args={'code': '20116952115', 'network_only': True})
2024-06-07 19:57:56.499 (MainThread) VERBOSE [matter_server.server.client_handler] [548168061712] Handling command commission_with_code
2024-06-07 19:57:56.499 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 10 (attempt 1/3).
2024-06-07 19:57:56.500 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Setting attestation nonce to random value
2024-06-07 19:57:56.500 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Setting CSR nonce to random value
2024-06-07 19:57:56.501 (Dummy-2) CHIP_DETAIL [chip.native.CTL] Stopping commissioning discovery over DNS-SD
2024-06-07 19:57:56.501 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Starting commissioning discovery over DNS-SD
2024-06-07 19:57:56.502 (Dummy-2) CHIP_DETAIL [chip.native.DIS] Warning: Attempt to mDNS broadcast failed on wlan0: src/inet/UDPEndPointImplSockets.cpp:416: OS Error 0x02000065: Network is unreachable
2024-06-07 19:57:56.504 (Dummy-2) CHIP_DETAIL [chip.native.DIS] mDNS broadcast had only partial success: 18 successes and 1 failures.
2024-06-07 19:57:56.505 (ThreadPoolExecutor-1_0) DEBUG [matter_server.server.storage] Saved data to persistent storage
2024-06-07 19:57:56.512 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device to be commissioned over DNS-SD
2024-06-07 19:57:56.512 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Attempting PASE connection to UDP:[fd0e:894b:f7b6:0:c7f0:b16a:f554:c29b]:5540
2024-06-07 19:57:56.512 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7f94001f00]: Allocated Type:1 LSID:37591
2024-06-07 19:57:56.512 (Dummy-2) CHIP_DETAIL [chip.native.SC] Assigned local session key ID 37591
2024-06-07 19:57:56.513 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<< [E:48815i S:0 M:109511587] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fd0e:894b:f7b6:0:c7f0:b16a:f554:c29b]:5540] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
2024-06-07 19:57:56.513 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7f94001f00]: Released - Type:1 LSID:37591
2024-06-07 19:57:56.513 (Dummy-2) CHIP_ERROR [chip.native.-] src/inet/UDPEndPointImplSockets.cpp:416: OS Error 0x02000065: Network is unreachable at src/controller/SetUpCodePairer.cpp:280
2024-06-07 19:57:56.590 (Dummy-2) CHIP_ERROR [chip.native.DIS] DNSSD packet parsing failed (for SRV records)
2024-06-07 19:57:56.590 (Dummy-2) CHIP_ERROR [chip.native.DIS] DNSSD packet parsing failed (for non-srv records)
2024-06-07 19:59:39.317 (Dummy-2) CHIP_DETAIL [chip.native.DIS] Warning: Attempt to mDNS broadcast failed on wlan0: src/inet/UDPEndPointImplSockets.cpp:416: OS Error 0x02000065: Network is unreachable
2024-06-07 19:59:39.318 (Dummy-2) CHIP_DETAIL [chip.native.DIS] mDNS broadcast had only partial success: 18 successes and 1 failures.
2024-06-07 19:59:39.319 (Dummy-2) CHIP_DETAIL [chip.native.DIS] SRV record already actively processed.
2024-06-07 19:59:39.320 (Dummy-2) CHIP_DETAIL [chip.native.DIS] Warning: Attempt to mDNS broadcast failed on wlan0: src/inet/UDPEndPointImplSockets.cpp:416: OS Error 0x02000065: Network is unreachable
2024-06-07 19:59:39.322 (Dummy-2) CHIP_DETAIL [chip.native.DIS] mDNS broadcast had only partial success: 18 successes and 1 failures.
MMAN
June 13, 2024, 7:51pm
13
I had the exact same situation and the thing that fixed it was making sure I had a local ipv6 address set up for all the devices. For whatever reason not having ipv6 set up on your router/the local inference will block it adding it to your HA even if it is set up in HomeKit
agners
June 14, 2024, 9:50am
14
It seems that there is no (current) route available to your Thread network
Do you use a Supervised or Container installation? There are some requirement to your Linux host to make sure router advertisments get properly processed: GitHub - home-assistant-libs/python-matter-server: Python server to interact with Matter
With Home Assistant OS, everything should be setup to work well out-of-the-box, including router reach-ability probing for fast failover etc.
@agners
I use Home Assistant OS with Supervisor on a Pi5 and NUC. Both don’t work with the same Log output.
@MMAN
Thanks. I don‘t have a IPv6 Internal Network setup on. Why should I? It’s way to cumbersome for a private network.
And the Eve is Thread/Bluetooth so there is so LAN/WLAN in the game.
And if Matter requires IPv6 in the Internal Network, I and many othe private users will not use it.
Bought a new Meross Matter Smart Plug. Tried to add it.
Same thing. Same error. Can not add it the neither of the Home Assistant OS Superviser Systems.
agners
June 23, 2024, 9:53am
17
Hm, so you also get the Attempting PASE connection to UDP:? What IP address is it displaying there? The Meross Matter smart plug is a WiFi device, so this should be a link local address.
What IPv6 settings do you have in the network configuration?
While you don’t need to setup IPv6 addresses manually, the Thread network requires IPv6 to be enabled to receive IPv6 neighbor discovery messages (Settings → System → Network, make sure IPv6 is set to Automatic).
Since you’ve added the Eve device to Apple Home, I assume you are using Apple devices as Thread border router? What is your Thread border router? Is it in the same network (no firewalling etc.)?
Problem solved.
First I had to activate IPv6 in my Home Network.
Second and more important:
Home Assistant is not able to add devices that are in a different VLAN.
HomeKit can do it easily.
That means that the Matter developers from Home Assistant have to do something to make it work over different VLANs.
