I’m struggling to get my Eve Motion (Thread) sensor to connect to my Home Assistant Thread network and would really appreciate some advice.
My setup
Home Assistant Green
Thread border router: Connect ZBT-1
Device: Eve Motion (Thread version)
The problem
This Eve Motion was previously paired with an Aqara Thread network (“AqaraHome-ad96”), which no longer exists.
Even after several factory resets, it keeps trying to rejoin that old network instead of pairing with my Home Assistant Thread network.
What I’ve tried so far
Factory reset of the Eve Motion
(holding the reset button inside the battery compartment for ~10 s → 5× red LED flashes)
Restarted Home Assistant and the Thread border router
Removed and re-added the device several times in the old Aqara setup
Always get the same error message in the HA app:
“Cannot connect to the Thread network ‘AqaraHome-ad96’.”
Question
**How can I completely erase the old Thread credentials from the Eve Motion so it joins my Home Assistant Thread network?
Thanks a lot for any tips or similar experiences!
— Andreas
Most likely you are using an iOS or Android App (such as the HA Companion App) and these Apps use the iOS/Android’s underlying Thread framework to manage Thread credentials. These frameworks pretty much stick with the first Thread credentials they ever learned, so in your case they are sticking with the Aqara Thread credentials. Are you using an App, and which one (iOS or Android)?
I’m using the Home Assistant app on Android, and back then I had also set up the Aqara Thread network via the Aqara app on Android.
Do you happen to know if there’s a way (on Android) to switch or remove the old Thread network that the Eve Motion is still trying to connect to?
I suspect that some cached Thread credentials might still be stored somewhere in the system of the Eve Motion sensor.
Big thanks to @wmaker for pointing me in the right direction
In the end, it wasn’t a problem with the Eve Motion or Matter itself, but rather with my Android phone / Google Play Services framework.
Here’s what I did to fix it:
On my Android phone, I went to Settings → Apps → Google Play Services → Storage → Manage space → Clear all data.
→ This completely reset the cached Thread network data.
After that, my Home Assistant Thread network was finally recognized correctly.
To be safe, I also performed a factory reset on the Eve Motion sensor (press and hold the reset button inside the battery compartment for ~10 seconds until 5× red LED flashes).
I then had to reinstall the Home Assistant app, because after clearing the Play Services data, adding new Matter devices didn’t work until reinstalling.
After these steps, everything worked flawlessly — the Eve Motion immediately joined the correct Thread network.
Thanks again for the help and for the insight that the issue wasn’t with the device, but with the smartphone/framework itself.
