Now ValvePosition
attribute is know by Matter server:
Awesome @lboue , thank you!
Sorry to go a bit offtopic, but a short question if anything has changed in the meantime.
I have a couple of eve thermo devices which are connected to my home assistant with a skyconnect as a homekit device.
I want to change that integration and use them over matter. Eve announced a long time back ago that there will be a android app but⦠yeah, they never deliveredā¦
Is it stil correct that i need a ios device which is capable of running the eve app (my iphone 6s is to old) AND a HomePod (2. Gen.) HomePod mini oder ein Apple TV 4K (2. Gen. / 3. Gen. 128 GB)?
So even if i invite a friend with a supported iphone to my home to do the update with his phone, i still need such a apple homepod to upgrade my thermo devices to matter? My Homeassistant server with a skyconnect wonāt work, right?
Would it be possible to visit a friend (who is owning a iphone with the eve app and a homepod mini) with my eve thermo devices, update them in his home, and add them over the now enabled matter connection to my homeassistant server? Has anyone any experiences with that?
Iāve upgraded mine to the Matter over Thread protocolso you can do it too.
I donāt know, I donāt have Google ecosystem. You can give it a try.
Itās the Eve iOS app that will upgrade the firmware to Matter, so you will need an iPhone (or iPad). I think this upgrade is handled by Bluetooth. But e.g. I had to reset all my Eve Thermo twice: Once to unbind them from the OTBR Thread network and set them up as new, then they get stuck and cannot be controlled in the Eve app, so then I reset them again. Only then I was able to access them from the Eve app and upgrade them to Matter. The entire process took about 15 minutes per device.
Thank you @lboue & @aleco !
I will test this out with a friendās iphone in a few days and will report here if anyone else is interested.
Looking forward to control my eve thermos over matter this winter
So, testet it, here are my result:
I did a reset on my eve thermo and configured it as a new device with a borrowed iphone with the eve app. But: I wasnāt able to do the upgrade to a matter device there. To upgrade to matter there are four checks that have to be all fullfilled inside the app:
- ios Version is the current one
- Thread Network available
- connected via thread
- battery status
The Thread Network available check always failed for me, not matter how often i did a reset on my thermo. Also i tried to add it as a new device to homeassistant, add it to the thread network and afterwards to the upgrade from the eve app, no luck because then the device was already coupled to another network.
So long story short: I organized a apple homepod mini, with that device the upgrade to matter went smoothly. Afterwards i did a reset on my eve thermo and was able to add it as a new matter device to homeassistant.
Will to this with every device and then return the iphone and homepod miniā¦inconvenient, but feasible
thanks for your help!
Hello again, now i have another question ;)ā¦
@lboue , thanks for your implementation of the new features! Iām now following the github project of the python-matter-server and found that your ValvePosition feature was already included in release 6.5.1 .
Thats also the version my homeassistant matter addon is using, but i do not have the feature of seeing the valveposition (yet).
My Eve thermo is running on the firmware version 3.5.0
Could you explain for me what is necessary in my setup until this feature is available for me? Do i have to do something? Does something else needs to be upgraded before ich will see the valveposition and your LocalTemperatureCalibration change?
And: Will Homeassistant will be able to update the firmware of my thermos in the future? Or is that something i always need the eve app for?
Thanks if anyone could explain this for me :),
Kind regards
Adding this in python-matter-server only allow the Matter controller to know the name of this attribute:
This doesnāt add anything to the web interface of Home Assistantās Matter integration, as itās managed elsewhere.
HA Matter component: core/homeassistant/components/matter at dev Ā· home-assistant/core Ā· GitHub
So youāll have to wait for the next update.
Regards
Ahh, understood, thank you :)!
You can try beta release-202410 version.
Iām new to home assistant. Iām looking to use my Eve Thermo with Versatile Thermostat.
For testing purpose, i have one eve thermo added via home kit into Home Assistant and itās working well in Versatile Thermostat but iām loosing the ability to control it via the Eve app.
So i switch one eve thermo to Matter. I can use it in Versatile Thermostat and still manage it in the Eve app (also itās way easier to add it to HA). Unfortunately, iām missing some variable/sensors when adding it via Matter.
For example, the temperature sensor doesnāt exist. I was able to go around this by a creating a template reading the climate temperature which is available.
Second example, it seems like Versatile Thermostat doesnāt know when the Eve Thermo (over Matter) is heating. So my boiler is not starting ⦠I think itās because the hvac_action is missing on the climate entity. Iām currently looking for a solution to this one.
My question is:
Does someone have any idea if a sensor temperature and the hvac_action will be added to the Matter implementation ?
I have 10 Thermo to add to HA but iām still wondering which way is the best to add them
Could you open another thread about hvac_action
for termostat? This is not specifically related to Eve Thermo.
Regards
Since Eve is now selling the Thermoās with Matter out of the box (no Apple device needed to upgrade the firmware), I got one to test it out as well (and planning to get more if I can get it all working).
Adding to HA worked perfectly fine, and I see the climate entity (which seems to work from preliminary testing) as well as the valve position. I do not see an entity for the temperature calibration, which is a kind of essential feature, too. I would like to use Better Thermostat or something similar with my Thermo and calibrate it to an external room temperature sensor.
Is this something that āshouldā already be available (like the valve position is), and something is wrong on my end? Or is this something that will need more time to be supported in Home Assistant?
My Thermo is using firmware 3.5.1 (updated to latest after adding it), Home Assistant Core is 2024.12.2 and the Matter Add-on is 6.6.1.
With Better Thermostat you have the option to use a external room temperature device, this works fine (for me).
But in one room i have a critical issue where the heater is placed in a postion, where the air accumulatesā¦: The Eve thermo Devices have a heat protection, which will not heat if the local temperature of the device reaches 30°C. But in this one room the thermostat reaches this 30°C long before the room is near the desired that temperature. The effect is sometimes that i cannot heat the room above 20°C⦠I think better thermostat would like to continue heating because of the configuration i made, but the eve thermo doesnāt allow it because of the protection.
Would be awesome to configurare any kind of offset for this matter device
