I’ve got the Eve Weather connected via the Homekit Controller via thread however after a unspecified period of time the sensors become unavailable and unable to reconnect without going through the process of resetting the device, adding to homekit, removing from homekit and then using the homekit controller.
Anyone out there have any luck getting this to work on a permanent basis?
Honestly it’s unclear to me what kind of connection it’s using. I used the Homekit Controller integration which i believe can use different types of connections from ip or bluetooth. In this case it might use bluetooth.
I’ve also enabled thread on the device so not sure what it is using right now
Seems to have failed once after about 2 weeks, not sure why though if it was my fault or not. After that it didn’t connect anymore so i had to reconfigure it from scratch yesterday.
@JediBrown i figured out the issue with the disconnections. I had a lot of disconnections and i couldn’t figure out why, it turns out the device was also present in HOMEKIT on my iphone and it was fighting with Home Assistant for control over the device. I’ve made sure the EVE device is no longer present in the iphone homekit and it worked perfectly after that.
