I bought a swiidinter cord switch and installed the device, it works, only, some events are sometimes missing.
I’m running home assistant on a raspberry pi 3 with aeotec z-stick gen5
If i place the light next to the controller, this is the info from the OZW_Log file:
2017-08-28 17:13:23.113 Detail, Node020, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x14, 0x03, 0x20, 0x01, 0xff, 0x3b 2017-08-28 17:13:23.113 Detail, 2017-08-28 17:13:23.113 Info, Node020, Received Basic set from node 20: level=255. Sending event notification. 2017-08-28 17:13:23.113 Detail, Node020, Notification: NodeEvent 2017-08-28 17:13:23.162 Detail, Node020, Received: 0x01, 0x09, 0x00, 0x04, 0x04, 0x14, 0x03, 0x25, 0x03, 0xff, 0x38 2017-08-28 17:13:23.162 Detail, 2017-08-28 17:13:23.162 Info, Node020, Received SwitchBinary report from node 20: level=On 2017-08-28 17:13:23.162 Detail, Node020, Refreshed Value: old value=false, new value=true, type=bool 2017-08-28 17:13:23.162 Detail, Node020, Changes to this value are not verified 2017-08-28 17:13:23.162 Detail, Node020, Notification: ValueChanged
But, if i move the device to the final position: this is the info from the OZW_Log file:
2017-08-28 17:12:39.844 Detail, Node020, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x14, 0x03, 0x20, 0x01, 0xff, 0x3b 2017-08-28 17:12:39.844 Detail, 2017-08-28 17:12:39.844 Info, Node020, Received Basic set from node 20: level=255. Sending event notification. 2017-08-28 17:12:39.845 Detail, Node020, Notification: NodeEvent
As you can see, the valueChanged notification isn’t reaching the controller. But the initial basic set is read.
Can some one help? Between the controller and the cord switch, there are some fibaro switches / dimmers wich repeat the signal.
Thank you!
