I would like to implement the following automation.
If the outside temperature is greater than the room temperature for 5 minutes and the window is open for at least 5 minutes, that send a notification.
When using the “events: state” - node i can set the “for”-value but once the condition is true it won’t get updated.
What i would like to have is the following behavior:
- outside temp e.g. 24°C, room temp 23.9°C → trigger the flow
- outside temp increases e.g. to 24.1°C → trigger the flow
The second trigger is not working. Is it possible? Or where is my mistake.
