b_tton
1
I need a bit help to get the example of the documentation running.
template:
- trigger:
trigger: event
event_type: my_event
binary_sensor:
- name: Event recently fired
auto_off: 5
state: "true"
My event:
I tried to change “my_event” to “press”. But this doesn’t work.
koying
(Chris B)
2
Event triggers are for actual events, not event entities (confusing, I know).
To trigger on an an event entity, you use the state platform.
See the examples at Event - Home Assistant
b_tton
3
Thanks a lot.
Working snippet:
template:
- trigger:
- platform: state
entity_id: event.button_event_z
binary_sensor:
auto_off: 1
state: "true"
I am missing an option to get the right event_type to get an on state at the binary_sensor only if I press once.
adding event_type: press
to the trigger results in an error of misconfiguration.
Do you any working option?
koying
(Chris B)
4
event_type
is an attribute of the entity, so:
- trigger:
- platform: state
condition: "{{ state_attr(trigger.entity_id, 'event_type') == 'press' }}"
