Event trigger failing to trigger (iOS Actionable Notifications)
I’m trying to get an automation to trigger based on an event being populated from the iOS actionable notification component. The notifications are setup and working correctly. When I click the button in the notification I am getting an event to populate on the event bus like this:
[homeassistant.core] Bus:Handling <Event ios.notification_action_fired[R]: actionName=YES, sourceDeviceID=iphonex, sourceDevicePermanentID=9CD9654F-3EAC-44F9-98B4-64624A7724A4, sourceDeviceName=iPhoneX>
The problem is that the action that is supposed to take place from this event doesn’t fire. Here is the automation that is supposed to trigger when the event bus sees the above message:
  - alias: Reset Actionable Boolean
    initial_state: True
      platform: event
      event_type: ios.notification_action_fired
      event_data:
        actionName: YES
      service: input_boolean.turn_off
      entity_id: input_boolean.actionable_test
The only thing the looks odd to me is that the event has an [R] after the
Any ideas what’s wrong here?
It was because my actionName was YES. It needs to have quotes around ‘YES’ or ‘NO’ apparently.
    initial_state: True
      platform: event
      event_data:
        actionName: 'YES'
