HA yelled at me this morning because it no longer likes my years-old automation based on my binary_sensor from my Ring Doorbell. This was my old automation:
But now I guess it wants me to use the Ding event rather than the binary_sensor:
I just can’t figure out what the syntax would be. The entity_id of the ding event is event.front_door_ding. Can anyone help?
Yes, event entities return a timestring for their state; just like the other “stateless” entity types: button, input_button, scene, and conversation. This timestring is when the event last occurred.
By using an open State trigger (without a defined to or from), the trigger will fire whenever the state updates. The attributes of the event entity should be static. If you want to be extra safe and guard against the possibility that an attribute change causes the trigger to fire, you can add a to or from or one of the “not” variations as follows:
What you show appears to be the legacy syntax, but it should work that way and continue to work that way al-be-it with a warning that it’s legacy syntax from Code Server Ha extension.
Unfortunately I dismissed the notifications a little too quickly, but I think it said that the binary_sensor would be removed in 2024.11.0. I’m not sure if it is a HA thing or specific to the Ring integration. But we’ll know in a couple of days!
Hi there,
Maybe somebody can help with a similar issue I am having.
I am trying to get my event doorbird doorbell ring to trigger an audio sound file.
So far I am able to get the sound clip to play (Run action in the automations section), but when I actually go to ring the doorbell nothing happens.
I have added this to a manual event (add trigger → manual event) as mentioned above
platform: state
entity_id: event.doorbird_outside_station_somebody_pressed_the_doorbell
not_to: unknown
Maybe I am not understanding this correctly and somebody can help.
Thanks a lot. Any help is highly appreciated.
The trigger configuration you have posted is a (improperly formatted) State trigger, but you claim:
… it cannot be both.
Please clarify what you are actually using and post the full automation. Showing only snippets often prolongs the process of us figuring out what is actually going on.
I don’t know what the button Set State means. I clicked on it, but nothing happens. Also I can look at the History showing that the Event was noted.
(I tried adding another screenshot, but I am limited to so many screenshots and replies)
So it seems that when I physically push the doorbell the state is recorded in Home Assistant. (Detected an event - 2 minutes ago)
@Didgeridrew
This is what I have set up as an automation. Under the “Add trigger” I have set it to “manual event” . So I guess I am going completely wrong with the “event data” section.
Right now, I have added an mp3 file to be played, just for testing purposes. This would then be replaced with a ding dong mp3 file.
Does this information help?
Thanks everybody for helping on this matter. I am fairly new to Home Assistant and appreciate any help on this.
Please follow Questions Guidelines #14 and #11 by sharing your automation’s configuration as properly formatted YAML…
Based on the provided screenshot you are using an Event trigger (labelled “Manual Event” in the “Add Trigger” menu). While it is possible to achieve your goal that way, it is more complicated and unnecessary. Since you have an event entity, the easier way is to use a State trigger. When using the graphical Automation editor, you can find State triggers either by typing “State” in the search bar of the “Add Trigger” menu or by selecting “Entity”, then “State”.
Be aware, in order to use the not_to configuration variable, you will need to edit the trigger in YAML which can be done by clicking the “breadcrumbs” menu and selecting “Edit in YAML”.
trigger: state
not_to:
- unknown
- unavailable
When complete it should look something like the following in the Automation editor:
@Didgeridrew Sorry about reviving this old thread, but I do have a question for you Didgeridrew.
Let’s say I am using the above state trigger to turn on a porch light. I would check for a change in the state (i.e., a new date and time) and then turn on the light. Here is my question:
Typically with a motion detector, the motion will clear (i.e., the Motion will change from detected to clear) and I will give an action to turn off the light. Since the state trigger retains the date and time that it was activated, how would I know when there was no longer motion present to turn off the light? Thank you so much for telling me how I can determine motion and activate an action. Now how do I determine motion has cleared and deactivate an action?
