Everspring AC301/Nexa ZRT-106 Z-Wave Radiator Thermostat
Hi!
I have bought this Z-Wave radiator thermostat with really nice price to functionality ratio, but unfortunately the default climate entity does not quite work with it. As far as I can tell, it follows the standard Z-Wave protocol so I would assume that most of needs to be done should be reusable. Or perhaps already there for some other device to be reused in order to support this.
Best regards,
Jonas
Product page: https://www.everspring.com/portfolio-item/ac301-trv-thermostatic-radiator-valve/
Product Manual: https://www.everspring.com/wp-content/uploads/2020/04/AC301-user-manual_04272020x.pdf
Device config excerpt from Z-Wave config XML
<Node id="5" name="" location="" basic="4" generic="8" specific="6" roletype="7" devicetype="4608" nodetype="0" type="General Thermostat V2" listening="false" frequentListening="true" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
		<Manufacturer id="60" name="Everspring">
			<Product type="15" id="1" name="Unknown: type=0015, id=0001" />
		</Manufacturer>
		<CommandClasses>
			<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="64">
				<Instance index="1" />
			</CommandClass>
			<CommandClass id="34" name="COMMAND_CLASS_APPLICATION_STATUS" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="5" innif="true">
				<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="21.5" />
			</CommandClass>
			<CommandClass id="64" name="COMMAND_CLASS_THERMOSTAT_MODE" version="3" innif="true">
				<Value type="list" genre="user" instance="1" index="0" label="Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
					<Item label="Off" value="0" />
					<Item label="Heat" value="1" />
					<Item label="Heat Econ" value="11" />
				</Value>
				<SupportedModes>
					<Mode index="0" label="Off" />
					<Mode index="1" label="Heat" />
					<Mode index="11" label="Heat Econ" />
				</SupportedModes>
			</CommandClass>
			<CommandClass id="67" name="COMMAND_CLASS_THERMOSTAT_SETPOINT" version="3" request_flags="2" innif="true" base="1" typeInterpretation="B">
				<Value type="decimal" genre="user" instance="1" index="2" label="Cooling 1" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
				<Value type="decimal" genre="user" instance="1" index="8" label="Dry Air" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
				<Value type="decimal" genre="user" instance="1" index="100" label="Unused 0_minimum" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0" />
				<Value type="decimal" genre="user" instance="1" index="101" label="Heating 1_minimum" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="5.0" />
				<Value type="decimal" genre="user" instance="1" index="200" label="Unused 0_maximum" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0" />
				<Value type="decimal" genre="user" instance="1" index="201" label="Heating 1_maximum" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="35.0" />
			</CommandClass>
			<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="4" innif="true">
				<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
				<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="4608" />
				<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="4608" />
			</CommandClass>
			<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="113" name="COMMAND_CLASS_ALARM" version="8" request_flags="2" innif="true">
				<Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="byte" genre="user" instance="1" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="byte" genre="user" instance="1" index="11" label="Power Management" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
			</CommandClass>
			<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Normal" value="0" />
					<Item label="-1dB" value="1" />
					<Item label="-2dB" value="2" />
					<Item label="-3dB" value="3" />
					<Item label="-4dB" value="4" />
					<Item label="-5dB" value="5" />
					<Item label="-6dB" value="6" />
					<Item label="-7dB" value="7" />
					<Item label="-8dB" value="8" />
					<Item label="-9dB" value="9" />
				</Value>
				<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
				</Value>
				<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Failed" value="0" />
					<Item label="Success" value="1" />
					<Item label="In Progress" value="2" />
				</Value>
				<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
			</CommandClass>
			<CommandClass id="117" name="COMMAND_CLASS_PROTECTION" version="1" request_flags="4" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Unprotected" value="0" />
					<Item label="Protection by Sequence" value="1" />
					<Item label="No Operation Possible" value="2" />
				</Value>
			</CommandClass>
			<CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
				<Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="100" />
			</CommandClass>
			<CommandClass id="129" name="COMMAND_CLASS_CLOCK" version="1" request_flags="4" innif="true">
				<Value type="list" genre="user" instance="1" index="0" label="Day" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="2" size="1">
					<Item label="Monday" value="1" />
					<Item label="Tuesday" value="2" />
					<Item label="Wednesday" value="3" />
					<Item label="Thursday" value="4" />
					<Item label="Friday" value="5" />
					<Item label="Saturday" value="6" />
					<Item label="Sunday" value="7" />
				</Value>
				<Value type="byte" genre="user" instance="1" index="1" label="Hour" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="18" />
				<Value type="byte" genre="user" instance="1" index="2" label="Minute" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
			</CommandClass>
			<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
				<Associations num_groups="1">
					<Group index="1" max_associations="1" label="Group 1" auto="true">
						<Node id="1" />
					</Group>
				</Associations>
			</CommandClass>
			<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
				<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
				<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6.04" />
				<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.01" />
			</CommandClass>
			<CommandClass id="152" name="COMMAND_CLASS_SECURITY" version="1" request_flags="4" innif="true">
				<Value type="bool" genre="system" instance="1" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
			</CommandClass>
		</CommandClasses>
	</Node>
Did you have any luck with this?
It turned out that with Z-Wave-JS it worked straight up with no further config needed. Not all features of the AC301 is supported, but it is enough to get it to work as I see it. You can set the setpoint and it reports back the current temperature reading…
Hello Jonas
Did you get your radiator thermostat from Nexa to work fully?
I just started using HA and bought a Nexa thermostat for my water radiators but I don’t seam to be able to set any values on the device. I can only see the current temperature and the setpoint. Even if I change the setpoint it seam to be set in the web gui but it eventually resets to 22 degrees and unprotected.
Did you do any more tricks or have I missunderstood something, like it is not possible to change the setpoint in the gui without creating a rule to transfer the value or something like that.
I see your xml-file but have no idea what to do with it…
Hi!
Well, not it works just like it should. I can access it through Z-Wave JS GUI or through HA GUI. It reports the current temperature, and updating the setpoint also works fine. I have not done anything in particular for this to work.
Best regards,
Jonas
Hi i am also have the same problem as @kafferejsarn this is a new problem it works in the spring and now when the cold it getting here it not working it just sets the temp to 22degrees.
Any luck with this? I have the same problem. 22 degrees is nice but to be able to change it would be nicer.
Hi, another Nexa ZRT-106 user here.
Same as you guys I cant get the unit to accept any settings updates.
I can see in the Z-wave log that the message are sent, and received, and rejected.
Im new to Z-wave so cant determine why the unit will rejects messages to update settings.
Another thing I cant figure out is how to set date/time on the unit. HA GUI has no settings here, and cant find in the manual if there any magic button presses that could be used?
Robert
Please post the logs.
There’s currently no UI or special service to set the clock. Here’s a discussion on how can set it using HA:
Also, this conversation is really in the wrong place…
Same issue with ZRT-106, using an Aeotec Z-Stick 7. I’ve attached my logs.
Subscribed to Z-Wave JS Log Messages…
2022-09-25T11:33:48.785Z CNTRLR   [Node 003] [setValue] calling SET_VALUE API ThermostatSetpointCCAPI:
                                    property:     setpoint
                                    property key: 11
                                    optimistic:   true
2022-09-25T11:33:48.792Z SERIAL » 0x012200a90103169f03700015dfea74692e04eece34dc7ec3db1314c85a2500000 (36 bytes)
                                  00043c6
2022-09-25T11:33:48.793Z DRIVER » [Node 003] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ transmit options: 0x25
                                  │ callback id:      67
                                  └─[Security2CCMessageEncapsulation]
                                    │ sequence number: 112
                                    └─[SupervisionCCGet]
                                      │ session id:      36
                                      │ request updates: true
                                      └─[ThermostatSetpointCCSet]
                                          setpoint type: Energy Save Heating
                                          value:         23 °C
2022-09-25T11:33:48.801Z SERIAL « [ACK]        (0x06)
2022-09-25T11:33:48.803Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-25T11:33:48.804Z SERIAL » [ACK]        (0x06)
2022-09-25T11:33:48.805Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-25T11:33:50.044Z SERIAL « 0x011d00a94300007a00a87f7f7f7f01010300000000420100007f7f7f7f7fe5    (31 bytes)
2022-09-25T11:33:50.045Z SERIAL » [ACK]        (0x06)
2022-09-25T11:33:50.047Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            67
                                    transmit status:        OK, took 1220 ms
                                    routing attempts:       1
                                    protocol & route speed: Z-Wave, 40 kbit/s
                                    ACK RSSI:               -88 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-09-25T11:33:50.070Z SERIAL « 0x011a00a8000103119f03d700113d44b2e4552158de9cdb51d700a8b0          (28 bytes)
2022-09-25T11:33:50.071Z SERIAL » [ACK]        (0x06)
2022-09-25T11:33:50.073Z DRIVER « [Node 003] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -88 dBm
                                    │ sequence number: 215
                                    └─[SupervisionCCReport]
                                        session id:          36
                                        more updates follow: false
                                        status:              Fail
                                        duration:            0s
2022-09-25T11:33:50.075Z CNTRLR   [Node 003] [setValue] result of SET_VALUE API call for ThermostatSetpointCCAPI
                                  : (SupervisionResult)
                                    status:   Fail
2022-09-25T11:33:50.076Z CNTRLR   [Node 003] [setValue] not updating value
2022-09-25T11:33:55.081Z SERIAL » 0x011b00a901030f9f037100bb46d190ac47f89c81d8b725000000004411        (29 bytes)
2022-09-25T11:33:55.082Z DRIVER » [Node 003] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ callback id:      68
                                    │ sequence number: 113
                                    └─[ThermostatSetpointCCGet]
2022-09-25T11:33:55.089Z SERIAL « [ACK]        (0x06)
2022-09-25T11:33:55.091Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-25T11:33:55.092Z SERIAL » [ACK]        (0x06)
2022-09-25T11:33:55.093Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-25T11:33:56.375Z SERIAL « 0x011d00a94400007e00a87f7f7f7f01010300000000420100007f7f7f7f7fe6    (31 bytes)
2022-09-25T11:33:56.376Z SERIAL » [ACK]        (0x06)
2022-09-25T11:33:56.378Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            68
                                    transmit status:        OK, took 1260 ms
                                    routing attempts:       1
                                    ACK RSSI:               -88 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-09-25T11:33:56.402Z SERIAL « 0x011b00a8000103129f03d800dd2d9cb7dd98d18b13aabe639e1000a89e        (29 bytes)
2022-09-25T11:33:56.404Z SERIAL » [ACK]        (0x06)
2022-09-25T11:33:56.406Z CNTRLR   [Node 003] [translateValueEvent: value updated]
                                    commandClass: Thermostat Setpoint
                                    endpoint:     0
                                    property:     setpoint
                                    propertyKey:  11
                                    internal:     false
                                    secret:       false
                                    event source: undefined
2022-09-25T11:33:56.407Z CNTRLR   [Node 003] [~] [Thermostat Setpoint] setpoint[11]: 19 => 19       [Endpoint 0]
2022-09-25T11:33:56.407Z CNTRLR   [Node 003] [translateValueEvent: value updated]
                                    is root endpoint:        true
                                    is application CC:       true
                                    should hide root values: false
2022-09-25T11:33:56.409Z CNTRLR   [Node 003] [translateValueEvent: value updated]
                                    endpoint:     0
                                    property:     setpointScale
                                    propertyKey:  11
                                    internal:     true
                                    secret:       false
2022-09-25T11:33:56.409Z CNTRLR   [Node 003] [~] [Thermostat Setpoint] setpointScale[11] [Endpoint 0] [internal]
                                  : 0 => 0
2022-09-25T11:33:56.410Z DRIVER « [Node 003] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -88 dBm
                                    │ sequence number: 216
                                    └─[ThermostatSetpointCCReport]
                                        value:         19 °C
2022-09-25T11:54:06.387Z SERIAL » 0x012000a90103149f0372002887739f98c6eb0c59f7db3a2c8904fa25000000004 (34 bytes)
                                  500
2022-09-25T11:54:06.388Z DRIVER » [Node 003] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ callback id:      69
                                    │ sequence number: 114
                                      │ session id:      37
                                      └─[ClockCCSet]
                                          clock setting: Sunday, 13:53
2022-09-25T11:54:06.395Z SERIAL « [ACK]        (0x06)
2022-09-25T11:54:06.397Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-25T11:54:06.398Z SERIAL » [ACK]        (0x06)
2022-09-25T11:54:06.399Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-25T11:54:07.616Z SERIAL « 0x011d00a94500007700aa7f7f7f7f01010300000000420100007f7f7f7f7fec    (31 bytes)
2022-09-25T11:54:07.618Z SERIAL » [ACK]        (0x06)
2022-09-25T11:54:07.620Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            69
                                    transmit status:        OK, took 1190 ms
                                    routing attempts:       1
                                    ACK RSSI:               -86 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-09-25T11:54:07.642Z SERIAL « 0x011a00a8000103119f03db0036ccd2dc28f25939e538e6c83600aa38          (28 bytes)
2022-09-25T11:54:07.644Z SERIAL » [ACK]        (0x06)
2022-09-25T11:54:07.645Z DRIVER « [Node 003] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -86 dBm
                                    │ sequence number: 219
                                        session id:          37
                                        status:              Fail
                                        duration:            0s
I thought there might be a S2 security issue, and I’ve tried to use a lower security level with the same result. I can’t get the Thermostat to accept any settings. I tried to send different commands manually thru the Z-wave API service, with the same result. I wonder how jonassam got it to work :thinking:
Hello and thanks for taking the time.
I will check out the date/time thread that you linked.
I agree that this thread no longer should be sorted as “feature request”.
I include the “silly log” of trying to change parameter 1 to the value 20
2022-09-26T18:55:27.261Z CNTRLR   [Node 004] [setValue] calling SET_VALUE API ConfigurationCCAPI:
                                    property:     1
                                    property key: undefined
                                    optimistic:   true
2022-09-26T18:55:27.280Z SERIAL » 0x012200a90104169f030400e0f22be832fefc375d5877c4c4ec90112fe52500000 (36 bytes)
                                  00009d0
2022-09-26T18:55:27.283Z DRIVER » [Node 004] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ callback id:      9
                                    │ sequence number: 4
                                      │ session id:      44
                                      └─[ConfigurationCCSet]
                                          parameter #:      1
                                          reset to default: false
                                          value size:       2
                                          value format:     SignedInteger
                                          value:            20
2022-09-26T18:55:27.291Z SERIAL « [ACK]        (0x06)
2022-09-26T18:55:27.295Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-26T18:55:27.296Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:27.299Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-26T18:55:28.582Z SERIAL « 0x011d00a90900007e00a77f7f7f7f01010300000000420100007f7f7f7f7fa4    (31 bytes)
2022-09-26T18:55:28.588Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:28.593Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            9
                                    routing attempts:       1
                                    ACK RSSI:               -89 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-09-26T18:55:28.608Z SERIAL « 0x011a00a8000104119f03780050f34bde703444eeb65511115700a776          (28 bytes)
2022-09-26T18:55:28.614Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:28.617Z DRIVER « [Node 004] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -89 dBm
                                    │ sequence number: 120
                                        session id:          44
                                        status:              Fail
                                        duration:            0s
2022-09-26T18:55:28.625Z CNTRLR   [Node 004] [setValue] result of SET_VALUE API call for ConfigurationCCAPI: (Su
                                  pervisionResult)
                                    status:   Fail
2022-09-26T18:55:28.627Z CNTRLR   [Node 004] [setValue] not updating value
2022-09-26T18:55:29.648Z SERIAL » 0x011b00a901040f9f030500af62c0c5ad595a8bd38a3225000000000a77        (29 bytes)
2022-09-26T18:55:29.651Z DRIVER » [Node 004] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ callback id:      10
                                    │ sequence number: 5
                                    └─[ConfigurationCCGet]
                                        parameter #: 1
2022-09-26T18:55:29.656Z SERIAL « [ACK]        (0x06)
2022-09-26T18:55:29.660Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-26T18:55:29.662Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:29.664Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-26T18:55:29.679Z SERIAL « 0x011d00a90a00000200a77f7f7f7f01010300000000020100007f7f7f7f7f9b    (31 bytes)
2022-09-26T18:55:29.681Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:29.684Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            10
                                    transmit status:        OK, took 20 ms
                                    routing attempts:       1
                                    ACK RSSI:               -89 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
2022-09-26T18:55:29.705Z SERIAL « 0x011b00a8000104129f03790054e9eb388f1f67eca03d9c2bc62b00a7ab        (29 bytes)
2022-09-26T18:55:29.710Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:29.716Z CNTRLR   [Node 004] [translateValueEvent: value updated]
                                    commandClass: Configuration
                                    endpoint:     undefined
                                    property:     1
                                    propertyKey:  undefined
                                    internal:     false
                                    secret:       false
2022-09-26T18:55:29.718Z CNTRLR   [Node 004] [~] [Configuration] 1: 120 => 120
2022-09-26T18:55:29.720Z CNTRLR   [Node 004] [translateValueEvent: value updated]
2022-09-26T18:55:29.723Z DRIVER « [Node 004] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -89 dBm
                                    │ sequence number: 121
                                    └─[ConfigurationCCReport]
                                        parameter #: 1
                                        value size:  2
                                        value:       120
edit:
The device doesnt seem to accept changes in date either, heres the log:
type or paste code here2022-09-26T19:28:02.139Z SERIAL » 0x012000a90104149f0307003e10254b7bfccdc21cff418cad789d6725000000000 (34 bytes)
                                  d1d
2022-09-26T19:28:02.142Z DRIVER » [Node 004] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ callback id:      13
                                    │ sequence number: 7
                                      │ session id:      46
                                      └─[ClockCCSet]
                                          clock setting: Monday, 21:26
2022-09-26T19:28:02.148Z SERIAL « [ACK]        (0x06)
2022-09-26T19:28:02.152Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-26T19:28:02.154Z SERIAL » [ACK]        (0x06)
2022-09-26T19:28:02.156Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-26T19:28:03.416Z SERIAL « 0x011d00a90d00007c00a67f7f7f7f01010300000000420100007f7f7f7f7fa3    (31 bytes)
2022-09-26T19:28:03.419Z SERIAL » [ACK]        (0x06)
2022-09-26T19:28:03.423Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            13
                                    transmit status:        OK, took 1240 ms
                                    routing attempts:       1
                                    ACK RSSI:               -90 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-09-26T19:28:03.442Z SERIAL « 0x011a00a8000104119f037e006a5120c82c6de585fe2880568800a667          (28 bytes)
2022-09-26T19:28:03.445Z SERIAL » [ACK]        (0x06)
2022-09-26T19:28:03.447Z DRIVER « [Node 004] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -90 dBm
                                    │ sequence number: 126
                                        session id:          46
                                        status:              Fail
                                        duration:            0s
Manuals:
Everspring AC301-1: https://manual.zwave.eu/backend/make.php?lang=en&sku=AC301-1&cert=ZC10-19126824
Nexa ZRT-106: https://manual.zwave.eu/backend/make.php?lang=en&sku=ZRT-106&cert=ZC10-22067099
Everspring AC301: Z-Wave JS Config DB Browser
Yes, this conversation should be moved to Zwave JS issues instead? I have contacted the manufacturer and after a while they found that with an old z-wave JS version there was no problems(don’t know which version they used) , but with the new version. So either there is a z-wave js problem or the thermostat firmware needs upgrade. Can someone verify this. Has anyone got the thermostat to work with the latest z-wave js version?
Is it possible to install an older version for debugging?
Is it possible that this issue is fixed?
I found this update relase from last week:
10.3.0 (2022-09-29)
onfig file changes
  • Disable Supervision for Everspring AC301 (#5119)
Based on this issue that describes the same as we are discussing:
https://github.com/zwave-js/node-zwave-js/issues/5118
Z-wave.me forum post:
Nexa ZRT-106 / Everspring AC301 - forum
Seems like a bug on the device for "supervision" that known for several other devices.
Hopefully I will find a free evening this week, but if anyone can use this to solve it please let ut know :slight_smile:
HA issue:
It definitely sounded like our problem and with the new z-wave JS update distributed today there was good hope that the problem was solved, but … no, not for me anyway.
I still can’t change any parameters. If you succeed , please let us know.
Did you re-interview the device?
Ahhh, I forgot! Made a complete reboot, but forgot to re-interview. Now it works. Great! Thank you for your help. :slight_smile:
Nice that fixed my problems to.
Is anyone using this one successfully with Better thermostat integration? One of mine is working like a charm but the other one is struggling and for some reason falls off and get’s stuck on full blast.
Something happened with the latest Z-wave JS update that broke one of my two TRV. After re-interview it shows up with some more settings and sensors for some reason. New is a “RF protection state” and rechagable, used as backup, overheating, fluid is low, battery is disconnected and battery temperature is low" they are all Unknown so I don’t know what’s happening here.
