Everspring AC301/Nexa ZRT-106 Z-Wave Radiator Thermostat
Hello and thanks for taking the time.
I will check out the date/time thread that you linked.
I agree that this thread no longer should be sorted as “feature request”.
I include the “silly log” of trying to change parameter 1 to the value 20
2022-09-26T18:55:27.261Z CNTRLR   [Node 004] [setValue] calling SET_VALUE API ConfigurationCCAPI:
                                    property:     1
                                    property key: undefined
                                    optimistic:   true
2022-09-26T18:55:27.280Z SERIAL » 0x012200a90104169f030400e0f22be832fefc375d5877c4c4ec90112fe52500000 (36 bytes)
                                  00009d0
2022-09-26T18:55:27.283Z DRIVER » [Node 004] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ transmit options: 0x25
                                  │ callback id:      9
                                  └─[Security2CCMessageEncapsulation]
                                    │ sequence number: 4
                                    └─[SupervisionCCGet]
                                      │ session id:      44
                                      │ request updates: true
                                      └─[ConfigurationCCSet]
                                          parameter #:      1
                                          reset to default: false
                                          value size:       2
                                          value format:     SignedInteger
                                          value:            20
2022-09-26T18:55:27.291Z SERIAL « [ACK]        (0x06)
2022-09-26T18:55:27.295Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-26T18:55:27.296Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:27.299Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-26T18:55:28.582Z SERIAL « 0x011d00a90900007e00a77f7f7f7f01010300000000420100007f7f7f7f7fa4    (31 bytes)
2022-09-26T18:55:28.588Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:28.593Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            9
                                    transmit status:        OK, took 1260 ms
                                    routing attempts:       1
                                    protocol & route speed: Z-Wave, 40 kbit/s
                                    ACK RSSI:               -89 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-09-26T18:55:28.608Z SERIAL « 0x011a00a8000104119f03780050f34bde703444eeb65511115700a776          (28 bytes)
2022-09-26T18:55:28.614Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:28.617Z DRIVER « [Node 004] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -89 dBm
                                    │ sequence number: 120
                                    └─[SupervisionCCReport]
                                        session id:          44
                                        more updates follow: false
                                        status:              Fail
                                        duration:            0s
2022-09-26T18:55:28.625Z CNTRLR   [Node 004] [setValue] result of SET_VALUE API call for ConfigurationCCAPI: (Su
                                  pervisionResult)
                                    status:   Fail
2022-09-26T18:55:28.627Z CNTRLR   [Node 004] [setValue] not updating value
2022-09-26T18:55:29.648Z SERIAL » 0x011b00a901040f9f030500af62c0c5ad595a8bd38a3225000000000a77        (29 bytes)
2022-09-26T18:55:29.651Z DRIVER » [Node 004] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ callback id:      10
                                    │ sequence number: 5
                                    └─[ConfigurationCCGet]
                                        parameter #: 1
2022-09-26T18:55:29.656Z SERIAL « [ACK]        (0x06)
2022-09-26T18:55:29.660Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-26T18:55:29.662Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:29.664Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-26T18:55:29.679Z SERIAL « 0x011d00a90a00000200a77f7f7f7f01010300000000020100007f7f7f7f7f9b    (31 bytes)
2022-09-26T18:55:29.681Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:29.684Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            10
                                    transmit status:        OK, took 20 ms
                                    routing attempts:       1
                                    ACK RSSI:               -89 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
2022-09-26T18:55:29.705Z SERIAL « 0x011b00a8000104129f03790054e9eb388f1f67eca03d9c2bc62b00a7ab        (29 bytes)
2022-09-26T18:55:29.710Z SERIAL » [ACK]        (0x06)
2022-09-26T18:55:29.716Z CNTRLR   [Node 004] [translateValueEvent: value updated]
                                    commandClass: Configuration
                                    endpoint:     undefined
                                    property:     1
                                    propertyKey:  undefined
                                    internal:     false
                                    secret:       false
                                    event source: undefined
2022-09-26T18:55:29.718Z CNTRLR   [Node 004] [~] [Configuration] 1: 120 => 120
2022-09-26T18:55:29.720Z CNTRLR   [Node 004] [translateValueEvent: value updated]
                                    is root endpoint:        true
                                    is application CC:       true
                                    should hide root values: false
2022-09-26T18:55:29.723Z DRIVER « [Node 004] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -89 dBm
                                    │ sequence number: 121
                                    └─[ConfigurationCCReport]
                                        parameter #: 1
                                        value size:  2
                                        value:       120
edit:
The device doesnt seem to accept changes in date either, heres the log:
type or paste code here2022-09-26T19:28:02.139Z SERIAL » 0x012000a90104149f0307003e10254b7bfccdc21cff418cad789d6725000000000 (34 bytes)
                                  d1d
2022-09-26T19:28:02.142Z DRIVER » [Node 004] [REQ] [SendDataBridge]
                                  │ source node id:   1
                                  │ callback id:      13
                                    │ sequence number: 7
                                      │ session id:      46
                                      └─[ClockCCSet]
                                          clock setting: Monday, 21:26
2022-09-26T19:28:02.148Z SERIAL « [ACK]        (0x06)
2022-09-26T19:28:02.152Z SERIAL « 0x010401a90152                                                       (6 bytes)
2022-09-26T19:28:02.154Z SERIAL » [ACK]        (0x06)
2022-09-26T19:28:02.156Z DRIVER « [RES] [SendDataBridge]
                                    was sent: true
2022-09-26T19:28:03.416Z SERIAL « 0x011d00a90d00007c00a67f7f7f7f01010300000000420100007f7f7f7f7fa3    (31 bytes)
2022-09-26T19:28:03.419Z SERIAL » [ACK]        (0x06)
2022-09-26T19:28:03.423Z DRIVER « [REQ] [SendDataBridge]
                                    callback id:            13
                                    transmit status:        OK, took 1240 ms
                                    routing attempts:       1
                                    ACK RSSI:               -90 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-09-26T19:28:03.442Z SERIAL « 0x011a00a8000104119f037e006a5120c82c6de585fe2880568800a667          (28 bytes)
2022-09-26T19:28:03.445Z SERIAL » [ACK]        (0x06)
2022-09-26T19:28:03.447Z DRIVER « [Node 004] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -90 dBm
                                    │ sequence number: 126
                                        session id:          46
                                        status:              Fail
                                        duration:            0s
Manuals:
Everspring AC301-1: https://manual.zwave.eu/backend/make.php?lang=en&sku=AC301-1&cert=ZC10-19126824
Nexa ZRT-106: https://manual.zwave.eu/backend/make.php?lang=en&sku=ZRT-106&cert=ZC10-22067099
Everspring AC301: Z-Wave JS Config DB Browser
