Hi everyone,
I have an EVERSPRING ST814 temperature and humidity sensor that no longer reports changes in temperature or humidity.
I tried to exclude and include the sensor again. I’m even trying to reset my z-wave key.
All of my other z-wave devices are working fine.
In my case the ST814 node id is 17. I have configured it to send a report every 10 minutes.
In the Z-wave JS logs, the report is saved but the values in home assistant are not updated
2021-08-04T15:14:02.796Z SERIAL « 0x010c0004001106310501220101f7 (14 bytes)
2021-08-04T15:14:02.815Z CNTRLR [Node 017] [Multilevel Sensor] Air temperature: metadata updated [Endpoint 0]
2021-08-04T15:14:02.820Z CNTRLR [Node 017] [~] [Multilevel Sensor] Air temperature: 24.1 => 25.7 [Endpoint 0]
2021-08-04T15:14:02.823Z SERIAL » [ACK] (0x06)
2021-08-04T15:14:02.831Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
└─[MultilevelSensorCCReport]
type: Air temperature
scale: Celsius
value: 25.7
2021-08-04T15:14:02.876Z SERIAL « 0x010c0004001106310501220101f7 (14 bytes)
2021-08-04T15:14:02.878Z CNTRLR [Node 017] [Multilevel Sensor] Air temperature: metadata updated [Endpoint 0]
2021-08-04T15:14:02.881Z CNTRLR [Node 017] [~] [Multilevel Sensor] Air temperature: 25.7 => 25.7 [Endpoint 0]
2021-08-04T15:14:02.883Z SERIAL » [ACK] (0x06)
2021-08-04T15:14:02.886Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
scale: Celsius
value: 25.7
2021-08-04T15:14:03.414Z SERIAL « 0x010b0004001105310505014490 (13 bytes)
2021-08-04T15:14:03.418Z CNTRLR [Node 017] [Multilevel Sensor] Humidity: metadata updated [Endpoint 0]
2021-08-04T15:14:03.422Z CNTRLR [Node 017] [~] [Multilevel Sensor] Humidity: 69 => 68 [Endpoint 0]
2021-08-04T15:14:03.426Z SERIAL » [ACK] (0x06)
2021-08-04T15:14:03.431Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
type: Humidity
scale: Percentage value
value: 68
2021-08-04T15:14:03.554Z SERIAL « 0x010b0004001105310505014490 (13 bytes)
2021-08-04T15:14:03.558Z CNTRLR [Node 017] [Multilevel Sensor] Humidity: metadata updated [Endpoint 0]
2021-08-04T15:14:03.561Z CNTRLR [Node 017] [~] [Multilevel Sensor] Humidity: 68 => 68 [Endpoint 0]
2021-08-04T15:14:03.565Z SERIAL » [ACK] (0x06)
2021-08-04T15:14:03.570Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
type: Humidity
value: 68
But on HA nothing change
Can anyone assist?
Z-Wave JS: Current version: 0.1.34
HA CORE Version: core-2021.8.0
Thanks!
