Every AddOn tells me "500 Internal Server Error"?!?!
Hi. I wanted to use the SMB-Backup-Tool and have seen “500 Internal Server Error” in the logs from the Add-On. I checked other Add-Ons - the same.
Also after uninstalling the SMB-Backup-Add-On still “500 Internal Server Error”.
Can someone tell me, how to fix this?
I’m having the same issue.
All log types except Home Assistant Core and Supervisor show “500 internal server error”.
Core 2024.11.3
Supervisor 2024.11.4
Operating System 13.2
Frontend 20241106.2
Hardware Raspberry Pi 3 (32-bit)
I do see the following in the Supervisor log each time I try to show it:
2024-12-01 21:41:01.789 ERROR (MainThread) [supervisor.api] Failed to get supervisor logs using advanced_logs API
  File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 1065, in write
    n = self._sock.send(data)
BrokenPipeError: [Errno 32] Broken pipe
  File "/usr/src/supervisor/supervisor/api/__init__.py", line 403, in get_supervisor_logs
    return await self._api_host.advanced_logs_handler(
  File "/usr/src/supervisor/supervisor/api/host.py", line 250, in advanced_logs_handler
    async with self.sys_host.logs.journald_logs(
  File "/usr/local/lib/python3.12/contextlib.py", line 210, in __aenter__
    return await anext(self.gen)
  File "/usr/src/supervisor/supervisor/host/logs.py", line 171, in journald_logs
    async with session.get(
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1360, in __aenter__
    self._resp: _RetType = await self._coro
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 690, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client_reqrep.py", line 1059, in start
    message, payload = await protocol.read()  # type: ignore[union-attr]
  File "/usr/local/lib/python3.12/site-packages/aiohttp/streams.py", line 644, in read
    await self._waiter
aiohttp.client_exceptions.ClientOSError: [Errno 32] Broken pipe
Same issue here.
All logs show internal server error except supervisor and core.
Core 2024.12.3
Frontend 20241127.8
Running on Arch.
Other functionality works fine. Just installed addons and updated core today.
Yeah, same issue
I have the same issue with my Add-Ons File Editor, Lets Encrypt, NGINX, Samba share, Terminal & SSH.
Any ideas?
  • Core2024.12.5
  • Supervisor2024.12.0
  • Operating System14.1
  • Frontend20241127.8
Same here, how to fix this please :bowing_man:
Following, same issue here.
Having this as well from time to time. It fixes automatically after some time. But no idea why and how.
I have exactly the same problem.
My HA verison :
  • Core 2025.1.0
  • Superviso r2024.12.3
  • Operating System 14.1
  • Interface utilisateur 20250103.0
2025-01-04 16:59:08.823 ERROR (MainThread) [supervisor.api] Failed to get supervisor logs using advanced_logs API
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1425, in __aenter__
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 730, in _request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/streams.py", line 671, in read
    await self._waiter
Following, same issue here. Solves itself on a reboot, but after breaks again after a few minutes.
Following, same issue for me also.
Who can have a solution?
I join, I also have this problem.
  • Core 2025.1.1
  • Supervisor 2024.12.3
i join also.
  • Core2025.1.2
  • Supervisor2024.12.3
  • Frontend20250106.0
I have the same issue.
Core: 2025.1.3
Supervisor: 2024.12.3
Operating system: 14.1
Front end: 20250109.0
Me too.
Core: 2025.1.4
Front end: 20250109.2
Same here: last update has also broken every AppDaemon app and I can’t see what’s wrong from the logs.
  • Core 2025.1.4
  • Operating System 14.2
  • Frontend 20250109.2
Same here…
Core: 2025.2.0b2
Supervisor: 2025.01.1
Operating System: Supervised installation on Ubuntu Oracular Oriole
Frontend: 20250130.0
New message
Any news on this? Even with the latest Update i can’t get my addon logs to show.
2025-02-12 05:51:13.573 ERROR (MainThread) [supervisor.api] Failed to get supervisor logs using advanced_logs API
        *args, identifier="hassio_supervisor", **kwargs
  File "/usr/src/supervisor/supervisor/api/host.py", line 257, in advanced_logs_handler
    async for cursor, line in journal_logs_reader(resp, log_formatter):
    ...<9 lines>...
            await response.write(line.encode("utf-8") + b"\n")
  File "/usr/src/supervisor/supervisor/utils/systemd_journal.py", line 101, in journal_logs_reader
    length_raw = await resp.content.readexactly(8)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 487, in readexactly
    raise asyncio.IncompleteReadError(partial, len(partial) + n)
asyncio.exceptions.IncompleteReadError: 0 bytes read on a total of 8 expected bytes
2025-02-12 05:51:13.607 ERROR (MainThread) [supervisor.api] Failed to get supervisor logs using advanced_logs API
    ...<9 lines>...
Just updated to the latest version and still can’t see the logs of my addons.
I’ve been able to download though.
