Every 'see available methods' redirect to developers homepage
Is that my browsers broken or hass developer docs broken?
For example: In page Hass object | Home Assistant Developer Docs , click ‘see available methods’ in hass section, and the page will be redirect to https:// developers. home-assistant. io/#homeassistant. core. HomeAssistant .
But actually it is just developers. home-assistant .io , the fragment identifier doesn’t work.
Yeah it’s not just you - I suspect someone has stuck a redirect somewhere.
Maybe bring it up on the Discord server - or log a issue on Github.
Thanks. I’ll submit a github issue.
Gus who come with the same problem can reply here: Every 'see available methods' in docs redirect to developers homepage · Issue #29765 · home-assistant/home-assistant.io · GitHub
