I’am a happy user of the EP1.
Last week i installed microphones in every ep1 i have around the house in the hopes i could make te ultimate sensor.
I made it work but not really reliable, after some time it times out and the mic is not responding anymore.
The voice assistant is not always active, or it is and after a while it just stops then i have to disable the wake word and actived it again to work.
Is the esp32-wroom not powerfull enough to run everything? or more likely am i making a mistake.
i will try to keep an eye out on the errors its trowing my way.
If i made a mistake hopefully somebody can help me make it more stable.
The following code is what i’am using:
substitutions:
room: "Woonkamer"
friendly_name: "Woonkamer Multisensor"
project_name: "Everything Smart Technology.Everything Presence One"
project_version: "1.1.7"
temperature_offset: "-3"
humidity_offset: "5"
temperature_update_interval: "60s"
illuminance_update_interval: "30s"
pir_delay_off: "10s"
occupancy_delay_off: "15s"
hidden_ssid: "false"
factory_reset_disabled: "true"
uart_target_output_disabled: "true"
uart_presence_output_disabled: "true"
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: true
project:
version: "${project_version}"
on_boot:
- priority: -100
then:
- wait_until: api.connected
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
esp32:
board: esp32dev
framework:
type: esp-idf
version: recommended
logger:
ota:
password: "****************"
api:
encryption:
key: "****************"
web_server:
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: ***
gateway: ***
subnet: ***
ap:
ssid: "Woonkamer Fallback Hotspot"
password: "***"
bluetooth_proxy:
captive_portal:
improv_serial:
i2s_audio:
i2s_lrclk_pin: GPIO18
i2s_bclk_pin: GPIO19
microphone:
- platform: i2s_audio
adc_type: external
i2s_din_pin: GPIO23
pdm: false
voice_assistant:
microphone: mic
use_wake_word: true
noise_suppression_level: 1
auto_gain: 31dBFS
volume_multiplier: 5.0
esp32_improv:
authorizer: none
dashboard_import:
package_import_url: github://everythingsmarthome/everything-presence-one/everything-presence-one.yaml@main
import_full_config: false
light:
- platform: status_led
name: ESP32 status LED
pin: GPIO32
entity_category: config
disabled_by_default: True
- platform: binary
restore_mode: RESTORE_DEFAULT_OFF
output: mmwave_led_output
output:
type: binary
write_action:
- switch.turn_off: mmwave_sensor
- delay: 1s
- if:
condition:
lambda: !lambda return state;
then:
- uart.write: "setLedMode 1 0"
else:
- uart.write: "setLedMode 1 1"
- delay: 1s
- uart.write: "saveConfig"
- delay: 3s
- switch.turn_on: mmwave_sensor
i2c:
sda: 26
scl: 25
scan: true
- platform: shtcx
temperature:
name: ${room} Temperatuur
filters:
- offset: ${temperature_offset}
- lambda: "return x + id(temperature_offset_ui).state;"
humidity:
name: ${room} Luchtvochtigheid
filters:
- offset: ${humidity_offset}
- lambda: "return x + id(humidity_offset_ui).state;"
address: 0x70
update_interval: ${temperature_update_interval}
- platform: bh1750
name: ${room} Lichtsterkte
address: 0x23
update_interval: ${illuminance_update_interval}
filters:
- lambda: "return x + id(illuminance_offset_ui).state;"
binary_sensor:
- platform: gpio
device_class: occupancy
pin:
number: GPIO15
mode: INPUT_PULLDOWN
- platform: gpio
pin:
number: 33
name: ${room} Bewegingsmelder
device_class: motion
filters:
- delayed_off: !lambda 'return id(pir_off_latency).state * 1000.0;'
filters:
- delayed_off: !lambda 'return id(occupancy_off_latency).state * 1000.0;'
on_state:
- lambda: 'id(illuminance_sensor).update();'
lambda: |-
if ( id(mmwave).state or id(pir_motion_sensor).state) {
return true;
else if (id(mmwave).state == 0 and id(pir_motion_sensor).state == 0) {
return false;
else {
return id(occupancy).state;
uart:
tx_pin: GPIO13
rx_pin: GPIO14
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
switch:
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
turn_on_action:
- uart.write: "sensorStart"
- delay: 1s
turn_off_action:
- uart.write: "sensorStop"
- delay: 1s
name: Use wake word
optimistic: true
on_turn_on:
- lambda: id(assist).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- voice_assistant.stop
- lambda: id(assist).set_use_wake_word(false);
name: UART presence output
internal: ${uart_presence_output_disabled}
optimistic: true
turn_on_action:
- delay: 1s
- uart.write: "setUartOutput 1 1"
- delay: 1s
- delay: 3s
turn_off_action:
- delay: 1s
- uart.write: "setUartOutput 1 0"
- delay: 1s
- delay: 3s
name: UART target output
internal: ${uart_target_output_disabled}
optimistic: true
assumed_state: false
turn_on_action:
- delay: 1s
- uart.write: "setUartOutput 2 1 1 1"
- delay: 1s
- delay: 3s
turn_off_action:
- delay: 1s
- uart.write: "setUartOutput 2 0"
- delay: 1s
- delay: 3s
number:
icon: mdi:arrow-left-right
min_value: 0
max_value: 800
initial_value: 315
optimistic: true
step: 15
restore_value: true
unit_of_measurement: cm
mode: slider
set_action:
- delay: 1s
- uart.write: !lambda int cm = (int)ceil(x / 15.0);
std::string cms = "detRangeCfg -1 0 " + to_string(cm);
return std::vector<unsigned char>(cms.begin(), cms.end());
- delay: 1s
- uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
- delay: 1s
name: mmWave off latency
icon: mdi:clock-end
min_value: 1
max_value: 600
initial_value: 15
optimistic: true
step: 5
restore_value: true
unit_of_measurement: seconds
mode: slider
set_action:
- delay: 1s
- uart.write: !lambda |-
std::string mss = "setLatency " + to_string(id(mmwave_on_latency).state) + " " + to_string(id(mmwave_off_latency).state);
return std::vector<unsigned char>(mss.begin(), mss.end());
- delay: 1s
- delay: 1s
name: mmWave on latency
icon: mdi:clock-start
min_value: 0
max_value: 2
initial_value: 0
optimistic: true
step: 0.25
restore_value: true
mode: slider
set_action:
- delay: 1s
- delay: 1s
- delay: 1s
name: mmWave sensitivity
icon: mdi:target-variant
min_value: 0
max_value: 9
initial_value: 7
optimistic: true
step: 1
restore_value: true
set_action:
- delay: 1s
- uart.write:
!lambda std::string mss = "setSensitivity " + to_string((int)x);
- delay: 1s
- delay: 1s
name: Occupancy off latency
icon: mdi:clock-end
min_value: 1
max_value: 600
initial_value: 15
optimistic: true
step: 5
restore_value: true
mode: slider
name: PIR off latency
icon: mdi:clock-end
min_value: 1
max_value: 120
initial_value: 10
optimistic: true
step: 1
restore_value: true
mode: slider
unit_of_measurement: "°C"
min_value: -20
max_value: 20
step: 0.1
mode: box
update_interval: never
optimistic: true
restore_value: true
initial_value: 0
icon: "mdi:thermometer"
on_value:
- lambda: 'id(shtc3_sensor).update();'
unit_of_measurement: "%"
min_value: -50
max_value: 50
step: 0.1
mode: box
optimistic: true
restore_value: true
initial_value: 0
icon: "mdi:water-percent"
on_value:
unit_of_measurement: "lx"
min_value: -50
max_value: 50
step: 1
mode: box
optimistic: true
restore_value: true
initial_value: 0
icon: "mdi:brightness-5"
on_value:
button:
- platform: restart
internal: true
name: Restart mmWave sensor
internal: true
on_press:
- uart.write: "resetSystem"
icon: mdi:restart
on_press:
- button.press: restart_mmwave
- button.press: restart_internal
- platform: safe_mode
internal: false
name: Factory reset mmWave
icon: mdi:cog-counterclockwise
internal: ${factory_reset_disabled}
on_press:
- delay: 1s
- uart.write: "resetCfg"
- delay: 3s
