Everything HA associated running slow
Hi all.
I noticed yesterday that all of a sudden my HA based automations are running relaly slowly. I looked at my error logs and there are loooooads of errors that keep coming up and devices keep disconnecting and reconnecting. I’m wondering if all the errors are causing a loop of things which is using up all the memory and causing the slowdown.
I have pasted a bit of the log below but I wondered if anyone has had this in the past and what caused it to suddenly go nuts.
It’s all different brand devices that I’m having an issue with so it doesn’t look to be one integration in particular, it seems like an whole HA problem.
Please help as this is driving me nits and my other half is moaning, “why can’t we just have a normal light switch?” SLAP!!
2024-04-23 22:54:21.735 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tuya_local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.737 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration octopus_intelligent which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.740 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.744 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hildebrandglow_dcc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.747 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration skyq which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.750 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration robovac which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.753 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration skodaconnect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.756 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration eufy_security which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.759 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.762 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.764 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration octopus_energy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:54:21.767 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration foxess which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-23 22:55:01.596 WARNING (MainThread) [custom_components.foxess.sensor] FoxESS1 has Cloud timeout or the Inverter is off-line, connection will be retried in 1 minute
2024-04-23 22:55:01.718 WARNING (MainThread) [custom_components.foxess.sensor] FoxESS2 has Cloud timeout or the Inverter is off-line, connection will be retried in 1 minute
2024-04-23 22:55:22.450 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-04-23 22:55:25.804 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('zha', 'da1ebb3a4jfjf2391b4f2'): 33jfjf266984, ('octopus_energy', '08396djfj4e9jffjb92ebe'): 338jffj666044, ('cast', '6ae3b315ajfjfje6bc8d3'): 33818.jff59636, ('met', '3d669121jfjfjfj12d2112c17f5efjjfe6d54'): 33818.6jfjfjjf8439, ('wyoming', '5ec19ebcjfjjffjc45237b462'): 3381jfjjf153, ('octopus_intelligent', '726ebe46jffjf5b3e529297eae8'): 338jfjf27945, ('flux_led', '741jfjfjf0jfjf501'): 338jfjf015, ('mqtt', 'e51050jffjf83c9dc986e19'): 33jfjjf453418, ('upnp', 'd58e1c8djfjffj86564749521b1'): 338jffj89564, ('local_calendar', '28272bbb789jffj8db3'): 33jffjfjjf2621, ('utility_meter', '0748e56875jfjfa5e8b82'): 338jffj831, ('utility_meter', '7f9fdf479caf5d9jffjfddf1'): 338jfjf35144, ('utility_meter', 'd8b7ac0e48jfffjjfc362e7989a'): 33jfjf9783, ('utility_meter', 'a22df19jfjf429b'): 33jfjfjf935, ('ping', '451jfjfedc5ebf13'): 338jffjfj229, ('ping', 'a8f0149jfjfjfaa08'): 33jfjfjfj5, ('ping', 'abd695cffjfjfjfj9a45f074de'): 3382jfjfjf053, ('tuya', 'f0eeda9089bca817921bda60c7230626'): 3382fjj9527, ('smartthings', '3b899be85bfjfjj1b8225'): 3382fjjf283, ('hacs', 'f44e3jffjfj6f4d32e4121573'): 3382jffjjf635, ('esphome', '60a563ae8jffjf8c62eaf0'): 338jffjjf245, ('esphome', 'a1b6dd63d0jfjfjf1523c1813'): 3382fjfjfjf853918}
2024-04-23 22:55:34.223 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.smart_meter_electricity_import_unit_rate (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2024-04-23 22:55:34.225 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.smart_meter_electricity_import_standing_charge (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2024-04-23 22:55:34.232 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.smart_meter_gas_import_unit_rate (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2024-04-23 22:55:34.233 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.smart_meter_gas_import_standing_charge (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2024-04-23 22:55:36.626 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_solar_now (<class 'homeassistant.components.template.sensor.SensorTemplate'>) is using state class 'measurement' which is impossible considering device class ('energy') it is using; expected None or one of 'total', 'total_increasing'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+template%22
2024-04-23 22:55:47.319 WARNING (MainThread) [zigpy.application] Zigbee channel 15 utilization is 98.93%!
2024-04-23 22:55:47.319 WARNING (MainThread) [zigpy.application] If you are having problems joining new devices, are missing sensor updates, or have issues keeping devices joined, ensure your coordinator is away from interference sources such as USB 3.0 devices, SSDs, WiFi routers, etc.
2024-04-23 22:56:19.628 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.dcc_sourced_smart_electricity_meter_cost_today (<class 'custom_components.hildebrandglow_dcc.sensor.Cost'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/HandyHat/ha-hildebrandglow-dcc/issues
2024-04-23 22:56:19.692 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.dcc_sourced_smart_electricity_meter_cost_today_2 (<class 'custom_components.hildebrandglow_dcc.sensor.Cost'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/HandyHat/ha-hildebrandglow-dcc/issues
2024-04-23 22:56:19.699 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.dcc_sourced_smart_gas_meter_cost_today (<class 'custom_components.hildebrandglow_dcc.sensor.Cost'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/HandyHat/ha-hildebrandglow-dcc/issues
2024-04-23 22:56:53.301 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'alexa_media' calls `async_add_job`, which is deprecated and will be removed in Home Assistant 2025.4; Please review https://developers.home-assistant.io/blog/2024/03/13/deprecate_add_run_job for replacement options at custom_components/alexa_media/__init__.py, line 625: hass.async_add_job(, please create a bug report at https://github.com/alandtse/alexa_media_player/issues
2024-04-23 22:56:54.520 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'alexa_media' calls `async_add_job`, which is deprecated and will be removed in Home Assistant 2025.4; Please review https://developers.home-assistant.io/blog/2024/03/13/deprecate_add_run_job for replacement options at custom_components/alexa_media/media_player.py, line 188: hass.async_add_job(, please create a bug report at https://github.com/alandtse/alexa_media_player/issues
logger: homeassistant.components.broadlink.updater
Source: helpers/update_coordinator.py:347
integration: Broadlink (documentation, issues)
First occurred: 23 April 2024 at 23:16:32 (59 occurrences)
Last logged: 14:33:47
  • Error fetching Dylans socket (BG800/BG900 at 192.168.6.209) data: [Errno -4000] Network timeout: No response received within 10s
  • Error fetching Hall Socket (BG800/BG900 at 192.168.7.12) data: [Errno -4000] Network timeout: No response received within 5s
  • Error fetching socket (BG800/BG900 at 192.168.6.212) data: [Errno -4000] Network timeout: No response received within 5s
  • Error fetching Back landing sockets (BG800/BG900 at 192.168.7.1) data: [Errno -4000] Network timeout: No response received within 5s
  • Error fetching James’s Socket (BG800/BG900 at 192.168.6.38) data: [Errno -4000] Network timeout: No response received within 5s
59 Occurrences since 23:16 last night, just for this error. What the hell is going on?
Logger: urllib3.connectionpool
Source: components/tuya/base.py:275
First occurred: 01:12:20 (19 occurrences)
Last logged: 14:43:45
Connection pool is full, discarding connection: apigw.tuyaeu.com. Connection pool size: 10
Please try to avoid spreading your issue over several Topics
And please read your log-files, it is still plain-text
Most of the first log-entries, is what it says " Warnings "with additional info how/what they means !
Basically most you can just Ignore, OR Do what is stated in the log-entry
And Yes there is actually “still” a common red-thread !. Configuration ( with clear-text explanations )
Have you by any chance looked into these Warnings !, tried what’s suggested , or Reported any Bugs ?
So basically most above is Warnings, which shouldn’t affect the overall performance, but please read and fix those which clearly says you can do something about.
Only thing that sticks out is
This is Most likely because either your Zigbee network sucks, OR You are Running Your WIFI on a WIFI-Channels which overlaps Your Zigbee-Channel, making, Choking the frequency !
You Have Network Issues, and Your Tuya is still a part of this, beside Zigbee
Which is why i linked your first Topic to this, as it’s quite relevant info there :wink:
So No, it’s Not HA, as you claim Here And in your First Topic
However your Network setup And Your Configurations is factors for you to look into
