I just received my Everything Presence Lite, so far so good.
I’m downloaded the add-on to configure the zones.
doesn’t matter if I create 2, 3 or 4 zones, when I click on save, I get a pop-up that says it has saved succesfully, but then the GUI deletes all the zones I just created.
If I check the entities, the zones don’t exist in the esphome/everything lite.
Hi, I’m experiencing the same issue. I’ve enabled all entities for all zones in the device configuration, but only regular zones are being saved. Every time I define an exclusion zone and click the ‘Save Zones’ button, it disappears. Only the regular zones are visible in the device configuration as well.
well, to be honest, if I try add exclusion zone once regular zones are already saved, it deletes all of them… really anoying and making this tool useless
I am having a similar issue, though for me I am trying to delete a zone, in my case an exclusion zone.
I right click and am prompted to click OK to delete the zone, I click OK but the zone remains. I’ve uninstalled and re-installed the add-on, but I cannot delete the zone.
I’ve also clicked the Factory Reset mmWave in the integration but that doesn’t seem to have any effect either.
