Hello. I am in need of help. I am running Home Assistant Supervised on Debian.
I have been using ZHA. One of my devices was not supported by it so I tried switching to Zigbee2mqtt. I have disabled ZHA when doing so. I have also uninstalled ModemManager from my Debian OS as recommended by the troubleshooting of Zigbee2MQ22 installation. After running Zigbee2MQ22, my Zigbee Sonoff Dongle was not able to identify any device and it would create error messages when pairing. For that reason I tried to switch back to ZHA.
To my surprise, all of my devices are shown as “unavailable”.
I tried to do a hard recovery to a previous stage before I began installation, but the problem persists.
The Debian Terminal states the error message “cp210x ttyUSB0: failed set request (0x12 status: -19)”
The OS is identifying the Dongle however the ZHA integration shows the Dongle as offline.
Diagnostics:
"home_assistant": {
"installation_type": "Home Assistant Supervised",
"version": "2022.8.7",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"os_name": "Linux",
"os_version": "5.10.0-16-amd64",
"supervisor": "2022.08.5",
"host_os": "Debian GNU/Linux 11 (bullseye)",
"docker_version": "20.10.17",
"chassis": "desktop",
"run_as_root": true
"custom_components": {
"hass_agent_mediaplayer": {
"version": "2022.5.6",
"requirements": []
"hacs": {
"version": "1.27.1",
"requirements": [
"aiogithubapi>=22.2.4"
"hass_agent_notifier": {
"version": "2022.3.15",
"requirements": []
"localtuya": {
"version": "4.0.2",
"requirements": []
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.33.1",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.78",
"zigpy-deconz==0.18.0",
"zigpy==0.50.2",
"zigpy-xbee==0.15.0",
"zigpy-zigate==0.9.2",
"zigpy-znp==0.8.2"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"config": {},
"config_entry": {
"entry_id": "0d3be2a17ea7b07028ce1744862ca10d",
"version": 3,
"domain": "zha",
"title": "Sonoff Zigbee 3.0 USB Dong - /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e81629895f29ec11a4d36d7840c9ce8d-if00-port0, s/n: e81629895f29ec11a4d36d7840c9ce8d - ITead - 10C4:EA60",
"data": {
"radio_type": "znp",
"device": {
"path": "/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e81629895f29ec11a4d36d7840c9ce8d-if00-port0",
"flow_control": null,
"baudrate": 115200
"options": {
"custom_configuration": {
"zha_options": {
"always_prefer_xy_color_mode": true,
"consider_unavailable_mains": 7200,
"consider_unavailable_battery": 21600,
"enable_identify_on_join": true,
"enhanced_light_transition": false,
"light_transitioning_flag": true
"zha_alarm_options": {
"alarm_arm_requires_code": false,
"alarm_failed_tries": 3,
"alarm_master_code": "**REDACTED**"
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "usb",
"unique_id": "**REDACTED**",
"disabled_by": null
"application_state": {
"node_info": {
"nwk": 0,
"ieee": "**REDACTED**",
"logical_type": 0
"network_info": {
"extended_pan_id": "**REDACTED**",
"pan_id": 6754,
"nwk_update_id": 0,
"nwk_manager_id": 0,
"channel": 11,
"channel_mask": 2048,
"security_level": 5,
"network_key": "**REDACTED**",
"tc_link_key": {
"key": [
90,
105,
103,
66,
101,
101,
65,
108,
108,
105,
97,
110,
99,
101,
48,
57
"tx_counter": 0,
"rx_counter": 0,
"seq": 0,
"partner_ieee": "**REDACTED**"
"key_table": [],
"children": [],
"nwk_addresses": {},
"stack_specific": {
"zstack": {
"tclk_seed": "801186fd46f9cc9c29110a674d9bbaca"
"metadata": {
"zstack": {
"TransportRev": 2,
"ProductId": 1,
"MajorRel": 2,
"MinorRel": 7,
"MaintRel": 1,
"CodeRevision": 20210708,
"BootloaderBuildType": 0,
"BootloaderRevision": null
"source": "[email protected]"
"counters": {},
"broadcast_counters": {},
"device_counters": {},
"group_counters": {}
"versions": {
"bellows": "0.33.1",
"zigpy": "0.50.2",
"zigpy_deconz": "0.18.0",
"zigpy_xbee": "0.15.0",
"zigpy_znp": "0.8.2",
"zigpy_zigate": "0.9.2",
"zhaquirks": "0.0.78"
