On Debian, yes I have an extension USB cable. Using ZHA.
Today I needed to reboot my server and now nothing on my zigbee network is working. I have a log file pasted here:
But here are the errors/warnings from Configuration->Logs (a lot shorter and easier to read)
Can’t read Supervisor data: Container addon_a0d7b954_ssh is not running
2:22:12 PM – (WARNING) Home Assistant Supervisor - message first occurred at 2:07:08 PM and shows up 3 times
Serial ‘/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466314-if00’ connection lost unexpectedly: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2:10:34 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py - message first occurred at 2:10:26 PM and shows up 2 times
Lost serial connection: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2:10:34 PM – (ERROR) /usr/local/lib/python3.9/site-packages/zigpy_deconz/uart.py - message first occurred at 2:10:26 PM and shows up 2 times
[0x9008:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError(’[0x9008:1:0x0006]: Message send failure’), DeliveryError(’[0x9008:1:0x0006]: Message send failure’), DeliveryError(’[0x9008:1:0x0006]: Message send failure’), DeliveryError(’[0x9008:1:0x0006]: Message send failure’)]
2:07:45 PM – (WARNING) Zigbee Home Automation - message first occurred at 2:07:22 PM and shows up 7 times
Error doing job: Task was destroyed but it is pending!
2:07:28 PM – (ERROR) runner.py
Legacy XMPP 0.9 protocol detected.
2:07:13 PM – (WARNING) /usr/local/lib/python3.9/site-packages/slixmpp/basexmpp.py
Using slower stringprep, consider compiling the faster cython/libidn one.
2:07:11 PM – (WARNING) /usr/local/lib/python3.9/site-packages/slixmpp/stringprep.py
And here’s my system info:
System Health
version: core-2022.2.9
installation_type: Home Assistant Supervised
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.0-11-amd64
arch: x86_64
timezone: America/New_York
GitHub API: ok
Github API Calls Remaining: 5000
Installed Version: 1.21.0
Stage: running
Available Repositories: 998
Downloaded Repositories: 3
logged_in: true
subscription_expiration: March 2, 2022, 7:00 PM
relayer_connected: true
remote_enabled: true
remote_connected: true
alexa_enabled: false
google_enabled: true
remote_server: us-east-1-0.ui.nabu.casa
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Debian GNU/Linux 11 (bullseye)
update_channel: stable
supervisor_version: supervisor-2022.01.1
docker_version: 20.10.12
disk_total: 226.3 GB
disk_used: 18.1 GB
healthy: true
supported: failed to load: Unsupported
supervisor_api: ok
version_api: ok
installed_addons: Plex Media Server (2.7.6), SSH & Web Terminal (10.0.2), Mosquitto broker (6.0.1), Node-RED (11.0.4), Log Viewer (0.12.2), Samba share (9.5.1), Insteon MQTT (1.1.1), Home Assistant Google Drive Backup (0.105.2), Studio Code Server (4.1.0), Z-Wave JS (0.1.54)
dashboards: 2
resources: 0
mode: storage
Any ideas? I sure hope I don’t have to rebuild my entire network!
