I am not getting my programming that I want in order. Could someone please tell me what I am doing wrong?
Situation: I have 3 students in my house and on each room I placed a radiator knob from evohome. I have placed Shelly window/door contacts on the windows. The idea was, when one of the students opened their window, the evohome radiator knob went to 6 degrees. I was able to create this in home assistant. I made a second automation when they close the window again that then the evohome radiator knob goes back to running the normal program. These two commands work perfectly.
Now I run into another problem, as they are students ;-). If the window is open and the radiator goes to 6% and the student manually turns the radiator knob to 22 degrees, the heating starts working again even though the window is open. I had been trying to make an automation that for example, checks every 15 minutes if the window is still open, and otherwise turns the radiator knob down to 6% degrees anyway. But this apparently doesn’t work, I must be doing something wrong.
Thanks in advance for the help. (I used google translate to compile the text, my apologies for errors)
alias: Studio Badkamer Raam open 6 graden
description: ""
triggers:
- type: opened
device_id: c76d65a3540902e29827634baee4abbc
entity_id: 8df0528a77b3b83f00d36dd555a7d3d2
domain: binary_sensor
trigger: device
conditions: []
actions:
- action: evohome.set_zone_override
entity_id: climate.studio_badka
setpoint: 6
- repeat:
sequence:
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
while:
- type: is_open
condition: device
mode: single
