Hi Guys,
I tried to get Evohome working today but no succes. I have changed in the configuration file the lines
Evohome
evohome:
username: remc******
password: ******
But the Home Assistent gives a error.
Hi Guys,
evohome:
password: ******
I’m getting the same thing, Evohome not working, here’s my error message:
ERROR (SyncWorker_15) [homeassistant.components.evohome] Failed to (re)authenticate with the vendor's server. Check that your username and password are correct. Message is: Unable to obtain an Access Token
It has worked OK in the past.
Can I ask are you using Hassio or Venv?
I am having the same issue and am running hassio
Exactly the same issue! Any idea?
