a good day
i have hass.io quit a time
but the 1 thing i want to worki is my evohome
if i am going away that the temp is set to away temp but noting works on that side
maybe somebody can help me in some way
regard m00s
a good day
regard m00s
On my todo list there is an evolution of the evohome component to include mode changes. Unfortunately I found I miss both time and know-how to do it
My current workaround is using IFTTT to set the thermostat mode from HA. If you need help feel free to ask for some details.
i do need some help with iftttt
its been a long time sinds my last post but now i have time or this kind of things to handle
the only thing i want to do is
when enter ad exit a home zone that everything is on on scheduleand when i leave that everything i on modus away
thanx allot for the effort
First, setup an IFTT account, enable the Honeywell evohome channel.
For scheduled: create an applet, use Webhooks for the THIS part, choose an event name like “honeywell_default”, choose Honeywell Evohome -> Disable a quick action for the THAT part.
For Away: create an applet, use Webhooks for the THIS part, choose an event name like “honeywell_away”, choose Honeywell Evohome -> Enable a quick action with action Away". you should end up with something like this:
In Home Assistant setup the IFTTT platform with your API Key, then setup two scripts:
honeywell_away:
sequence:
- service: ifttt.trigger
data_template: {"event":"honeywell_away", "value1":"", "value2":"", "value3":""}
honeywell_default:
sequence:
data_template: {"event":"honeywell_default", "value1":"", "value2":"", "value3":""}
Then you can setup two automations:
- id: honeywell_away_when_out
alias: Termostato Away uscendo
- platform: state
entity_id: group.all_devices
to: 'not_home'
- service: script.turn_on
entity_id: script.honeywell_away
- id: honeywell_default_when_in
alias: Termostato Normale rientrando
- platform: state
to: 'home'
entity_id: script.honeywell_default
thanx allot for the help everything workt out
but still its strange that there is not a good fix with the evohome
i used domoticz and there works everything fine
but again thanx allot
Nog i have a nother question is it also possible to Change the temp
And That i can set for only 1 zone
I would like to know the same. How can you set the temp for 1 zone specific ?
I only configured the Honeywell component and it recognized my 4 zones as 4 different independent thermostat. The operation mode (“Away”) doesn’t work, but the temperature setpoint does work fine.
climate:
- platform: honeywell
username: !secret honeywell_username
password: !secret honeywell_password
region: eu
scan_interval: 20
Thats true but if you going away then you want your thermostat to a loer degree or if yiu Come home you want is to a higher degree and then comes the ifttt Come in handy
And the region is not Needed its standard eu if let it blank
Try to make a New Applet and the Webhooks give it a name and the search on evohome scroll Down and thera it is set temp to zone
Is scan_interval 20 reliable for you @namadori? I’m using 200 at the moment and it’s way too slow.
Yes, for me 20 is working fine.
