Hope you well. Well yes and no I guess, Depends on which sonoff integration you using ? the traditional integration works fine as the HA is always looking at the eWelink Severs (Online) If you using AlexxIT/Sonoff integration this one gives me the issue as it doesn’t update the devices as fast as you would like it to as it (my understanding) updates a file in the sonoff directory periodically.
I would like to automate a Binthen hinge motor that uses the eWelink application. I use AlexxIT integration. Can the motor be added to HA like other Sonoff components?
What is traditional integration for this device?
Curtains work well in automation. The only problem is that the open or closed status is not loaded.
I’ve created a request and I’m waiting for it to be added to the SonoffLAN integration.
