tom_l
June 25, 2019, 2:02am
2
That appears to be a sonoff 3-gang switch. You could flash it with Tasmota or ESPhome or use this custom component: Sonoff /eWeLink component for original firmware
but this is for hass, I have hassio.io , I do not have these folders and I did not want to use the tasmota
tom_l
June 25, 2019, 4:07am
4
That custom component works with Hassio. You create the sub-folders in your /config directory.
If you don’t want to use Tasmota or ESPhome it’s your best option.
of error:
Unable to install package uuid: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')"))': /simple/uuid/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')"))': /simple/uuid/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')"))': /simple/uuid/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')"))': /simple/uuid/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')"))': /simple/uuid/
ERROR: Could not find a version that satisfies the requirement uuid (from versions: none)
ERROR: No matching distribution found for uuid`
tom_l
June 25, 2019, 5:36am
6
Similar error here caused by pihole blocking the connection: Sonoff /eWeLink component for original firmware
You would be better off reading (or at least searching) the entire thread and, if you can’t find a solution, posting the error in the custom component thread and including some details of what you did to cause it.
