eWeLink Smart Home Integraation
Hi I am trying to integrate eWeLink to HA. I have followed the instructions regarding Long-Lived Access Token etc. and have installed the Add-on. However when I go to the Config tab there is no field to enter the Long-Lived Access code., only a field that shows Port 3000/TCP.
I have uninstalled, re-installed and also rolled back my HA to prior to installing the eWeLink Add-on, then re-installed but I always get the same issue. Your help would be most appreciated. Thank you Al
TRY USE FROM HACS
For added privacy you can also use SonoffLAN which can be installed through HACS (HACS → Integrations).
Works very well here with numerous eWeLink based devices for years now without any hiccups :+1:t3:
Thank you. I am a newly to this so any guidance as to how to install the HACS would be most welcome. Al
Look here:
How to install hacs?
or here
How to Install HACS on Home Assistant
There are plenty of guides on the Internet. Just use your favorite search engine to find more.
Thank you very much!
you made my day.
