I just updated to version 11.2024 after reading the release notes for WebRTC support. But I dont have any information how to implement / recognize my existing Reolink PoE cameras into HA dashboard using WebRTC. Any suggestions / support is apprechiated.
If your Reolink cameras are already configured in Home Assistant you don’t have to do anything special. Use a picture or picture glance card on your dashboard and HA will make it all happen for you.
It’s possible that you were previously running webRTC or go2rtc add-ons and that has you turned around.
The only thing you need to do id make sure default_config: is a key in your configuration.yaml, That gives you all the default ones.
If you don’t want to run the default ones, you need go2rtc: key minimum.
