There seems to be a shortage of good examples of using ESPHome without Home Assistant. In particular, it took me quite some time to work out how to get an M5Stack Atom Matrix (with it’s single button and 5x5 RGB LED matrix display) to toggle on/off to a specific light effect.
So here is my working example.
Main YAML
# M5 Atom Matrix Configuration for m5atom01 which is an M5Stack Atom Matrix
# ESP32 Pico, 8x8 RGB LED Matrix (WS2812C), Infra-red LED,
# MPU6886 Inertial Sensor - 6-axis attitude sensor with 3-axis gravity accelerometer and 3-axis gyroscope
# NB: This configuration does not use Home Assistant (HA). It uses TotallyInformation's standard MQTT Schema for ESP devices.
# Pins/GPIO
# === M5Stack Atom Matrix Specific ===
# @see https://github.com/m5stack/M5Stack/blob/31be29f3f743768778accb8d5f308583ba4d3d4c/src/utility/Config.h
# @see https://docs.m5stack.com/#/en/core/atom_matrix
# ------ Buttons ------
# BUTTON_PIN | 39 | Under LED's and on side - both are the same button
# ------ RGB LEDs PIN ------
# RGB_PIN | 27 | 8x8 matrix, WS2812C
# ------ Infra-Red LED PIN ------
# INFRA_PIN | 12 |
# -------- I2C ---------
# SDA | 25 |
# SCL | 21 |
# MPU6886 Inertial Sensor - I2C Address 0x68
# ---- Exposed Ports ----
# -- | 3V3 | 5-pin connector pin 1
# 19 | Tx | 5-pin connector pin 3
# 22 | Rx | 5-pin connector pin 2
# 23 | Neo | 5-pin connector pin 4 (Connected to 34 via 100ohm resistor?)
# 33 | Adc | 5-pin connector pin 5
# 21 | SCL | 4-pin connector pin 1
# 25 | SDA | 4-pin connector pin 2
# -- | 5V | 4-pin connector pin 3
# -- | Gnd | 4-pin connector pin 4
# -- | Gnd | Grove connector pin 1
# -- | 5V | Grove connector pin 2
# 26 | | Grove connector pin 3
# 32 | | Grove connector pin 4
# WARNING: When using FastLED lib, the recommended maximum brightness of RGB LED is 20
substitutions: # All have to be strings, the substitution process will convert them to the correct types
devicename: m5atom01
upper_devicename: M5ATOM01
mqtt_root: ESP
mqtt_prefix: $mqtt_root/$devicename
publish_interval: 50s
ipaddress: <<REPLACE WITH YOUR REQUIRED IP ADDRESS>>
wifi_power_save_mode: light # none, light, high
wifi_fast_connect: "true"
log_level: debug # none, error, warn, info, debug, verbose
esp_platform: ESP32
esp_board: m5stick-c
# todo: move secrets to here and file to root
sun_latitude: !secret sun_latitude
sun_longitude: !secret sun_longitude
mqtt_broker: !secret mqtt_broker
mqtt_username: !secret mqtt_username
mqtt_password: !secret mqtt_password
<<: !include includes/mqtt.yaml # For some reason, the config checker doesn't like this as a package
packages: # These allow merging whereas global includes do not
logger: !include includes/logger.yaml
wifi: !include includes/wifi.yaml
common: !include includes/common.yaml
common_sensors: !include includes/common-sensors.yaml # Includes number, text and binary
common_switches: !include includes/common-switches.yaml
common_intervals: !include includes/common-intervals.yaml
# Define I2C interface
i2c:
sda: 25
scl: 21
scan: true
#frequency: 200kHz
# output:
# - platform: ledc # 5x5 RGB Matrix (WS2812C)
# pin: 27
# id: matrix
binary_sensor:
- platform: gpio # btn
pin:
number: 39
inverted: true
on_click:
then:
- if:
condition:
- light.is_on: matrix_light
then:
- light.turn_off: matrix_light
else:
- light.turn_on:
effect: rainbow
# --- End if binary_sensor: --- #
light:
- platform: fastled_clockless # 5x5 RGB Matrix (WS2812C)
pin: 27
chipset: WS2812
num_leds: 25
color_correct: [50%, 50%, 50%] # The LED's on the Atom Matrix should not be run at full power
effects:
- addressable_rainbow:
# --- End of light: --- #
# EOF
includes/mqtt.yaml
# Configuration for the MQTT Broker.
# The configuration variables must be set in the master YAML file.
mqtt: # Home MQTT Broker
broker: $mqtt_broker
username: $mqtt_username
password: $mqtt_password
topic_prefix: $mqtt_prefix
log_topic: # no log to MQTT, it isn't needed and isn't that useful unless you subscribe something to it.
birth_message:
topic: $mqtt_prefix
payload: Online
retain: true
will_message:
topic: $mqtt_prefix
payload: Offline
retain: true
shutdown_message:
topic: $mqtt_prefix
payload: Shutdown
retain: true
discovery: false # No HA discovery, we aren't using HA
#--- End of mqtt ---#
logger: # Enable logging
level: $log_level
includes/wifi.yaml
# NB: secrets.yaml has to be in the same folder as this file
wifi:
ssid: !secret WiFi_SSID
password: !secret WiFi_password
domain: !secret WiFi_domain
# Try to speed up connection
fast_connect: $wifi_fast_connect
manual_ip:
static_ip: $ipaddress
gateway: !secret WiFi_gateway
subnet: !secret WiFi_subnet
dns1: !secret WiFi_DNS1
power_save_mode: $wifi_power_save_mode
ap:
ssid: "${upper_devicename} Fallback Hotspot"
password: !secret WiFi_AP_Password
#--- End of wifi ---#
esphome:
comment: $device_description
platform: $esp_platform
board: $esp_board
build_path: builds/$devicename
on_boot:
- mqtt.publish:
topic: $mqtt_prefix/info/protocol
payload: ESPHome
web_server:
port: 80
time:
- platform: sntp
timezone: Europe/London
ota: # Allow push OTA updates - https://esphome.io/components/ota.html?highlight=ota
sun: # https://esphome.io/components/sun.html
latitude: $sun_latitude
longitude: $sun_longitude
# Standard sensor definitions. Comment in/out as desired
# Include as a PACKAGE in your master device YAML file
# NB: - This configuration does not use Home Assistant (HA). It uses TotallyInformation's standard MQTT Schema for ESP devices.
# - Sensors with an id but no name are automatically marked as `internal`
# Sensors with numeric outputs
# How long since the device was restarted? In seconds.
- <<: !include sensors/uptime.yaml
# The WiFi RSSI signal strength in Db
- <<: !include sensors/wifi_signal.yaml
# The WiFi RSSI signal quality as a %
- <<: !include sensors/wifi_quality.yaml
# How far is the sun above/below the horizon?
- <<: !include sensors/sun_elevation.yaml
# At what absolute compass bearing is the sun?
- <<: !include sensors/sun_azimuth.yaml
# Sensors with text outputs
text_sensor:
# IP address, URL, SSID, BSSID, device MAC address
- <<: !include text_sensors/wifi_info.yaml
# The base build version of ESPHome used in the compile
- <<: !include text_sensors/esphome_version.yaml
# Next sunrise/sunset times (HH:mm:ss)
- <<: !include text_sensors/sunrise.yaml
- <<: !include text_sensors/sunset.yaml
# Template Text Sensor Timestamp - Output by Interval below - https://esphome.io/components/text_sensor/template.html
# Requires sntp_time component. Defined in common.yaml
lambda: |-
char str[25];
time_t currTime = id(sntp_time).now().timestamp;
//strftime(str, sizeof(str), "%Y-%m-%d %H:%M:%S", localtime(&currTime));
strftime(str, sizeof(str), "%Y-%m-%dT%H:%M:%S.000Z", gmtime(&currTime));
return (std::string) str;
- platform: template # Template text sensor wifi channel
lambda: |-
// --- ESP8266 version ---
//std::string out;
//char buffer[64];
//sprintf(buffer, "%u", wifi_get_channel());
//out.append(buffer);
//return out;
// --- ESP32 version ---
wifi_ap_record_t wifidata;
esp_wifi_sta_get_ap_info(&wifidata);
std::string out;
if (wifidata.primary != 0) {
char buffer[64];
sprintf(buffer, "%u", wifidata.primary);
out.append(buffer);
return out;
binary_sensor:
- platform: status
switch:
- platform: restart # Define a restart switch (allows mqtt restart)
# Standard interval definitions. Comment in/out as desired
interval:
# Run every ${publish_interval} but only if MQTT is connected, publish updated/updated_by/wifi-channel to MQTT
- interval: ${publish_interval}
then:
- wait_until:
mqtt.connected:
- mqtt.publish:
topic: $mqtt_prefix/status/updated
payload: !lambda |-
return id(systime).state;
- mqtt.publish:
topic: $mqtt_prefix/status/updated_by
payload: $upper_devicename/ESPHome
- mqtt.publish:
topic: $mqtt_prefix/info/channel
payload: !lambda |-
return id(wifi_channel).state;
Sorry, not included the lower-level sensor includes, ask if you want them.
This is set up so that I can reuse the majority of the code on different device types. Also note that I use MQTT (with Node-RED) and not Home Assistant.
